20 Most Recent
OCE 3140 Copier Questions & Answers
I have oce tds 400. the problem is 22501 error.
This is a safety relay issue. Shut off the unit, and unplug it from the wall. Open the left side cover and check the brass contacts to the fuser unit by carefully sliding back the protective tubes. If there is a lot of corrosion on there, it could be causing your issue. However this error can be any number of things. It may also be the LVPS. It's best to call an authorized Oce representative to come take a look at it.
Oce tds400 error-22501
Power off and on the machine. If that doesn't solve it it may be the CPU i/o PBA. Please call an Authorized Oce Service Representative.
HOW TO PUT DEVELOPER IN OCE 9400
Take out the developer assembly, vacuum it out completely and put in new developer. Generally this is done by a trained Oce technician.
Oce 9400 code error 0401
Oce (Canon) has discontinued support on this product. I would invest in a newer model where parts would be in stock.
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:Turn OFF the copier.Press and keep pressed the Utility key and turn On the copier.Keep pressed the Utility key and wait while Trouble reset message displayed.Release the Utility key and touch the message.Turn OFF the copier ,wait 1 minutes and turn ON.
E805
Hello Peter; E805 is cooling fan problem;
0002& 0003is fuser fan, 0004 to 0006 is laser fan 0007 is exhaust fan, 0008 system fan, 0010 & 0011 low voltage fan, 0012 & 0013 reader fan, 0014 to 0016 drum fan, 0017 is controller fan, 0018 scanner fan.
