20 Most Recent
Capcom MegaMan: Maverick Hunter X for PSP Questions & Answers
Does anyone else have a
No you dont have a defective PSP. I have experienced this problem and I am used to it as this usually this happens if there is a newly installed game on your PSP or in your case the Megaman Maverick Hunter X. Try uninstalling that game and it would fix the problem.
Hope this helps. Should you need further assistance, please let me know. Thank you for using FixYa.
No dash
you must first get the ULTIMATE ARMOR LEG PART. (in chill penguins stage.) then press circle. if that doesnt work then the problem is with the button on your unit.
Find local setting folder
I will answer this in a Liner sequence. Follow step by step.Start>Control Panel>Folder Options>View>check Show Hidden Files and Folders>uncheck Hide Extensions for known File types >Hide Protected Operating System Files and folders. Start>Computer>C:/Users>[your username/username of local settings you want to find\]>Local Settings.If access is denied you can take ownership of the folder if your using an administrator account.Right click - Properties>Security>Select [your username]>Advanced>Owner>Edit>[select your username]> check Replace Owner on sub containers and objects>Apply>YesClose all windows and reopen.Do not attempt to alter settings in this folder It can lead to serious damage to your computer and / or applications. Altering settings in this folder will at the very least cause programs to stop running properly. There is nothing in this folder that can be used to fix a computer.
