20 Most Recent Stanley Bostitch Coil Framing Nailer Questions & Answers
Does the Bostitch N12 coil nailer need oiling, or is it oil-less?
Use Bostitch sb32 oil or another pneumolube and this is an example option to use an oil nebulizer between the compressor and most mechanical airtools. z-b0stfo5oy-bh5ghn1qnqby53unjdzuuvc3-2-0.jpg
3/23/2019 7:45:09 PM • Stanley Bostitch... • Answered on Mar 23, 2019
Fires first nail will not fire second nail
Ez test. With nails removed, and door open driver should be at top of cylinder. If driver is down replace piston oring. If driver is up, lightly strike nose of gun against softwood. The driver should stay at top. If driver drops with light tap replace piston oring. If driver stays at top dry fire the nailer against softwood. The driver should hit the softwood leaving a mark and return to top. If driver stays down or does not travel all the way up pull the cylinder and make sure checkband is installed. Checkband is oring or rubber band covering series of holes on lower part of cylinder. Good luck
11/16/2016 7:27:19 PM • Stanley Bostitch... • Answered on Nov 16, 2016
Want to buy in singapore
then email everwin company its similar to bostitch and are made Taiwan.
4/29/2016 5:54:56 PM • Stanley Bostitch... • Answered on Apr 29, 2016
2answers
Bostitch n80 does not feed nails
make sure that the feeder spring is not broken this stops nails or can jam them or cause them to skip. Some nail gun types work bette if you buy their brand of nails, but it could possibly just be dirty or maybe check the nail size. You should also have a way to adjust how far your nails are in the bucket where you put your nails, it should go up or down by spining it.
4/25/2016 6:05:55 PM • Stanley Bostitch... • Answered on Apr 25, 2016
My Bostitch Nailer only fires one Nail and the piston sticks down at end of nail that goes into the wood, I have to take off the air connection to get it to go back for the next nail can anyone help m
Top seal on the top of the Cilinder is not fitting to tight. or broken if you can turn it it has stuck motionless tight
11/11/2015 6:38:13 PM • Stanley Bostitch... • Answered on Nov 11, 2015
N88 bostitch nailer fires when connecting air hose
I have seen this on dewalt nailers also, caused by trigger valve worn. on Bostitch nailer part # tva6 remove roll pins retaining trigger and trigger valve. one roll pin for trigger and one or two for valve. With pins removed apply air pressure to gun popping out the valve. Use glove or folded-up shop rag to catch the valve as I pops out. Be sure to reduce air pressure as it could come out with force. Good luck
10/18/2015 5:01:18 PM • Stanley Bostitch... • Answered on Oct 18, 2015
2answers
My framing Bostitch air gun , model N95RHN blows
prolly clogged, buy a rebuild kit and use it making sure all parts are totally clean before reassembly. in the future be sure to drain your compressor at least daily after use (more on wet or humid days) to avoid this
2/8/2015 10:46:40 PM • Stanley Bostitch... • Answered on Feb 08, 2015
I has 1987 nissan run good on low rpm when i atep on gas to get more rpm it's star skeeping (in gear or not in gear)
You have a bad fuel injector or spark plug. Run a fuel system cleaner through your car and check the plugs for wear. If you need further help, I’m available over the phone at https://www.6ya.com/expert/nathaniel_9ed79ef078a2f164
12/31/2014 4:58:50 PM • Stanley Bostitch... • Answered on Dec 31, 2014
Stanley coil roofing nailer not sinking 3 1/4
That model may not be designed for that length nail. Check with your local supplier.
9/11/2014 1:48:58 PM • Stanley Bostitch... • Answered on Sep 11, 2014
My bostitch roof nain gun blow air thur the
Check the troubleshooting manual for resolution
8/19/2014 4:59:58 PM • Stanley Bostitch... • Answered on Aug 19, 2014
How do i rebuild a 1979 gm Rochester carburetor ?
Try to locate a "rebuild kit" from a parts store or online. When you locate one, ask if it includes the complete instructions to install the kit. I have rebuilt several dozen, and kits have an instruction sheet. Be blessed.
5/21/2014 2:17:28 AM • Stanley Bostitch... • Answered on May 21, 2014
0answers
Dewalt D51822 trigger goes 1/2 way without
Dewalt nailers use some orings that are made of vinyl (clear to yellow in color instead of buna or viton). These orings fail by getting soft and sticky. The gun may not leak but will not work correctly. The trigger should fire the gun when depressed about 1/2 way in. The oring repair kit has the same orings. I use generic orings in the gun to solve the problem. There are two orings inside the gun that should be changed and at least two on the trigger valve stem. In time the gun may fire a nail when you connect the hose. Check the internet for recall on some of these guns. The orings in the gun that should be replace make contact between the white cylinder spacer and the cylinder (smaller is standard oring # 141 the larger is 74.4mm x 3.1mm). The two rings on the trigger stem are 2mm x 1.5mm . If you do not have a source for orings then just replace the trigger valve. You also might try setting the depth adjustment all the way down. Good luck.
9/5/2013 3:55:15 PM • Stanley Bostitch... • Answered on Sep 05, 2013
Stanley Bostitch Coil Framing Nailer Logo
81 questions posted
Top Stanley Air Tools & Compressors Experts
john h
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Air Tools & Compressors
Most Popular Question
bostitch nailer only fires one nail
  • Air Tools & Compressors
