20 Most Recent
Ace Hardware Ace Heavy Duty Staple Gun Hammer Tacker Questions & Answers
Problem loading gun..Where do we put in the
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Won't shoot staples
look for a jammed staple near the end of the magazine that is stopping them from advancing. Also make sure they move freely in/on the magazine. Double check to ensure that you are using the right staples for this tool.
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
Removal Storage
If you are looking for a company who use latest equipments then i would refer you to appoint "bison removals" or "guildford removals". These two companies have excellent instruments to make your removal effortless.
