20 Most Recent Arrow T50 Staple Gun Tacker Questions & Answers
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Arrow T50 Staple... | Answered on Mar 23, 2011
Open up the stapler and look for a jammed staple near the opening the staples c0ome out of, had this very same problem, just a few screws to open the gun up and a small screwdriver to pop the staple out.
Arrow Tools &... | Answered on Jan 12, 2018
Product description
Product description
2750-1378 Features: -Revolutionary design with ergonomic handling.-Easy release drop in loading channel for staples.-Battery contains an easy to read LED charge meter.-Built-in safety switch prevents accidental firing.-Adjustable staple drive with depth of drive dial.-Light weight design for prolonged stapling tasks.-Can use T50 type 1/4'' staples (2750-0719), T50 type 5/4'' Monel staples, T50 type 5/16'' staples, T50 type 5/16'' Monel staples, T50 type 3/8'' staples, T50 type 3/8'' Monel staples, T50 type 1/2'' staples, T50 1/2'' Monel staples, T50 type 9/16''.-staples, and T50 type 17/32'' Ceiltile staples. Includes: -Kit includes case, charger, and tool. Specifications: -10.8 volts.
staples needed for arrow fastener ct50 Google Search
Contact Arrow to order this part. While you're at it, order several because they are easily lost -- and you rarely notice it when they fall off in mid-job.
Arrow Tools &... | Answered on Jan 10, 2018
Arrow T50 Staple Gun Tacker Logo
14 questions posted
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Arrow Tools & Hardware - Others
Most Popular Question
need instructions refill arrow t50
  • Tools & Hardware - Others
