20 Most Recent Remington 16" Electric Chain Saw Questions & Answers
check oil lines and when storing saw stand on end or on side blade up.. vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Remington 16"... | Answered on Apr 10, 2019
your clutch is bad and how old is this saw if it is too old it would not be worth fixing
Remington 16"... | Answered on Aug 28, 2017
should be a 5/32 file
Remington 16"... | Answered on Feb 12, 2015
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
Remington 16"... | Answered on Dec 31, 2014
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Remington 16"... | Answered on Apr 16, 2014
Not that I know off. But it could be. look at the owner's manual to find out. Since it is electric, it may have one . It could also be the switch .
So look at that possibility too.
Try different cords and different outlets to make sure it is not one of these.
Remington 16"... | Answered on Nov 23, 2013
If you can't move the chain around the bar it is too tight.Back off the tension.Put on some gloves and see if it will move. If it was so loose that it came off the driver links could have been damaged and you will need to replace the chain because the drivers have burs on the side of them and are to wide to slide in the grove of the bar
Remington 16"... | Answered on Nov 04, 2013
probably Metric.. go to a hardware store with the saw and get one that fits
Remington 16"... | Answered on Oct 05, 2013
http://www.masterparts.net/remingtonelectricchainsaw.html
Remington 16"... | Answered on Apr 05, 2013
Remington 16" Electric Chain Saw Logo
131 questions posted
Top Remington Garden Experts
Thomas F. Schneider
roeb
Joseph Mueller
Joseph Mueller
Are you a Remington Garden Expert? Answer questions, earn points and help others
View Most Popular
Remington Garden
  • Remington Garden
Most Popular Question
need order new 16 chain remington chain
  • Garden
