20 Most Recent
Makita JR3050T Recipro Saw 9 Amp Questions & Answers
How do I remove the boot guard on my makita
They are one of the hardest to remove - we usually clamp the end of the boot in a vise and using a couple screwdrivers from the handle end, turn the boot inside out and peel it off.
I have just bought this
Hi marill469,
Here is a website where you can download the owner's manual for your saw: http://www.retrevo.com/d/ds/progress?doc=e045b5a9143e1e2ea028b778addd77ca&rk=0.7594880065395843
The instructions for blade insertion and removal are on page 7.
As far as I know, there is no upside down on a recip saw blade. You can use it either way. Upside down allows you to get the blade in tighter spaces due to the shape of the saw.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
This thing vibrates so much that I can't feel
For the most part they do vibrate, that's why it is good to make use of the blade guard when cutting. It cuts back on the vibration. I have hand to use a saw without having that guard against what I was cutting and I thought I was going to have my arm fall off. You may want to check to see that the blade and that part the blade goes into are nice and tight. I've used many saws on different jobs, the best brand of saw for the vibration standpoint that I've found is Craftsman.
Wiring varible speed swith for a Makita JR3000V reciporcating saw
The replacement switch, is it Makita and was it a direct replacement for the original part? That could make a difference. I looked at the schematics for this tool and they do not furnish the wiring codes but I think you are on the right track. To make sure though I would call Makitas tech support people at 1-800-4625482 and have a wiring explosion sent to you. Let me know if you still need more help and I will contact them or call a local dealer that I know.
I have a makita 2703
First thing I would check are the Carbon Brushes. The are # 75 in the picture
Hope this answers all your questionsPlease remember to Rate/vote for any solution that helps you out.Thanks for using Fixya.
10/12/2022 4:35:39 AM •
Makita Saws
Answered
on Oct 12, 2022
