20 Most Recent Dewalt DC618KA Angled Nailer Kit Questions & Answers
Yes, if it is not pushing the safety back far enough. Also check for pieces of nails debris in the slave slide.
Dewalt DC618KA... | Answered on Nov 18, 2017
Its the compressor... not enough pressure.
Dewalt DC618KA... | Answered on Dec 02, 2016
Had the same problem with mine. Remove the 3 screws on top and remove the lid. on mine the firing pin assembly was jammed. If the roller seems to be holding the pin carriage too tight then you need to prise up the spring mechanism over the carriage. To do this go to the end at the back of the machine and insert a screwdriver between the top carriage and the frame. prise gently and it should pop up. the firing pin should now move freely
Dewalt DC618KA... | Answered on Dec 05, 2015
dewalt nailgun jamming "constantly"
Dewalt DC618KA... | Answered on Feb 27, 2015
Remove 2 screws on metal front cover.
Remove screws holding handle halves together and carefully separate (Be careful because trigger spring can fly out on you).
This will expose the belt and allow replacement. There is a spring loaded idler pulley so removal & replacing is easy.
Dewalt DC618KA... | Answered on Feb 07, 2015
Check the driver blade assy, it might be stuck or bent.
Dewalt DC618KA... | Answered on Jan 04, 2013
The link below is where you can download the owners manual. The link is on that page near the top right hand side under the area marked downloads. Page 5 will show you were the switch is located that switches the tool from sequential fire to bump fire.
DeWalt DC618 parts and operations manuals
Dewalt DC618KA... | Answered on Aug 22, 2012
They are a very complicated tool. You can use this link to view the parts diagram but I would highly recommend taking it to an authorized DeWalt servicing dealer. We are one and I hate working on those tools so I can just imagine how hard it would be for someone not experienced in them.
DeWalt DC618KA parts diagram.
Usually caused by stuck head valve or stuck driver. Remove the head and lube the headvalve with white grease or silicone paste. Pull the driver and lube the cylinder making sure that the driver does not fit too tightly in the cylinder.
Dewalt DC618KA... | Answered on Nov 27, 2011
http://www.dewalt.com/Find-Service-Center-Results.aspx
Try some 3 in 1 oil on the tip, but that probably won't work. It sounds like your windings are being being power hogs and you might need different brushes.
Dewalt DC618KA... | Answered on Jul 12, 2011
go to dewaltservicenet.com and on the left side of page type in your model number and it will allow you to download the breakdown you are looking for. Let me know if you need more assistance.
Dewalt DC618KA... | Answered on May 04, 2011
Parts and parts diagram available at www.toolpartsdirect.com
I use this company quite a bit for parts. Good luck.
Dewalt DC618KA... | Answered on Apr 15, 2011
Dewalt DC618KA Angled Nailer Kit Logo
43 questions posted
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Tools & Hardware - Others
Most Popular Question
need part schematic model dc618
  • Tools & Hardware - Others
