20 Most Recent
Kohler Persuade Two-Piece Elongated Toilet with Dual Flush Technology, with Questions & Answers
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
I can see water trickeling
The problem is your flapper.
It is leaking water into the bowl, causing the valve to kick in as the water level slowly drops in the tank.
It will also solve most condensation issues as well.
Toilet running and won't stop.....it
When water goes over into overflow tube then that means 2 things.
The rubber flapper at tank bottom is good and does not need replacement at this point.
That leaves 2 possible problems.
1) The flush valve needs to be adjusted so water turns off sooner.
Flush valve lets water into the tank.
For example if you have a float ball on end of brass rod, just bend the brass rod so the float sits lower in the water.
If you have the 'fluidmaster' then a float rides up and down with water level. There is a metal rod with a metal clip. Squeeze the metal clip and move it downward on the metal rod.
2) If water will not turn off after adjusting flush valve, then replace flush valve.
Local hardware store sells the part and can help with instructions.
You need a crescent wrench or large adjustable pliers.
Plumber can also install the flush valve.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plunbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
I'm about to install a kohler
Are you talking about the slot where the two screws hold the base down to the floor?
If so, that is called a closet flange. You will need to pick one up at Home Depot or Lowes. There are various kinds. If your floor is a concrete pad then you may have to get one that just slides down inside your waste pipe. It can be glued in. If you are upstairs and have a wooden sub floor you can get one with treated deck screws to screw into the floor.
If you have a digital camera, tale close up pictures of the waste site and take them to the store and show them to someone who works in the department. He will know what you need.
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
