20 Most Recent
Daewoo KOR-63DB Microwave Oven Questions & Answers
I have a daewoo microwave
The flash and the pop that happened on your microwave has blowned the thermal fuse or the power diode. Now I strongly suggest that you don't try replacing it on your own because even an unplugged (open) microwave can seriously injure someone because of the high voltage capacitor inside (you could get electrocuted).
However if you are hearing a buzz and it doesn't heat then another point of failure could be the magnetron or the diode itself needs to be replaced.
Since it's just 6 months since you bought it, initial warranties for appliances are usually good for 1 year so I would rather have you bring it back to the store where you purchased it (together with the receipt) have them send it for repairs or replace the unit for you.
Next time try using a UPS or make sure that the unit is turned off before plugging it into a power outlet.
Hope this helps!
Daewoo microwave KOR-6QAB is not
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
YOUR
SAFETY IS PARAMOUNT
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
Check the door interlock switches first then the
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
I would like to purchase
Daewoo UK model glass turntable trays can be purchased
here.
Microwave oven
THERE IS SPECIAL MWAVE CAVITY SPRAY .MAKE SURE YOU SANDPAPER IT THEN USE NORMAL PRIMA ALLOW TO DRY USE FINE SANDPAPER JUST TO MAKE SURFACE RIGID THE SPRAY
Microwave stopped working...
If it's still under the 12-month warranty, I'd contact Daewoo customer service: http://www.e-daewoo.com/customer_service.asp
Even if it's not they may be able to help you. That page also has a link to help you find a local authorized servicer and download the owner's manual if you don't have yours.
I'd say you have a bad membrane keypad.
We're happy to help and we appreciate your thoughtful rating of our answer.
Daewoo KOR-7LREM Retro micro
Sporadic:sometimes heats up the food & most of the time doesn't heat like it should-have to add time to the recommended time but getting increasingly unreliable.
Does it have a turn table that spins your food container? If so, does it turn? If not, you are getting a solid directed beam of microwaves focused on one part of your food leaving the rest of it ignored. If it doesn't have a turn table, it will have a wave spreader inside which is nothing more than an aluminum fan that is sometimes driven by a small motor and rubber belt. You won't see this as it is inside the chamber that contains the magnetron that generates the microwaves. These belts can break allowing a solid, focused microwave beam to shine on your food rather than be distributed around the oven, again, leaving the rest unwarmed. If this is the case, using the oven can damage it over time. If you don't know what you are doing, DO NOT try to repair it yourself!!! If you don't get the outer casing back together properly, you can expose yourself and / or your family to dangerous amounts of microwave radiation. You should take it to a qualified service center for repair but I would venture a guess that it is already damaged because of your statement "but getting increasingly unreliable". Even if it isn't damaged, it will probably cost you more in labor to fix it than it would cost to replace it. Good luck.
