20 Most Recent
Franke VNX-120-45 Vision Double Bowl Undermount Stainless Steel Kitchen Sink Questions & Answers
We purchased a franke double sink at lowes for
Take it back out and clean all of the plumbers putty off. make sure that the bottom of the sink and the basket is clean and dry. Take a good quality silicone caulk and make a 1/4" bead all the way around the basket where it meets the sink. Tighten the basket nut till it gets nice a snug but not os that you spin the basket much. Then let the caulk setup over night. Trim away the excess with a sharp knife from the top and hook up the drain. This will seal a basket everytime. I never use plumbers putty anymore.
5/21/2014 8:46:46 PM •
Franke...
Answered
on May 21, 2014
Drain stopper is stuck
try turning the top of stopper with fingers. They are generally " locked in with a twist" and can be unlocked the same way. good luck!
9/1/2014 5:03:00 AM •
Franke Home
Answered
on Sep 01, 2014
Franke plug seal problem
Adjust the clip underneath the sink to a different hole on the rod so it will tighten more when used.
5/1/2014 3:07:04 PM •
Franke Home
Answered
on May 01, 2014
The half bowl of our
Replace the drain and plug with a new one while using silicone to seal the upper and lower half of the drain.........It is also a good practice to lubricate the rubber washer as well...........Wait 24 hours and it should be good to ge........Hope this helps.
3/25/2014 7:15:41 PM •
Franke Home
Answered
on Mar 25, 2014
We bought a Franke top
Is the Foot print of the replacement maybe sink smaller than the foot print of the orginal sink that was replaced? It sounds like it is. Make the hole smaller by cutting a plywood strip to be placed on two sides of the sink hole. Long side at back of sink and short side. (plywood needs to be marine type because of the high mosture of the sink area and painted)
I went to their web site; they have posted a buyer beware notice of bad contractors. They may be able to help.
[email protected]
11/29/2010 6:26:55 AM •
Franke Home
Answered
on Nov 29, 2010
I cant figure out how
We can't figure it out either! It seemed to come with undermount pieces (its not an undermount sink) and some blurry IKEA-style instructions. Been working on this 3 hours!
Anybody...???
9/5/2010 2:36:04 AM •
Franke Home
Answered
on Sep 05, 2010
Fragranite black sink . How do i clean off white
here is the info from the
www.franke.com website (UK):
under FAQs:
How do I best clean my Fragranite Sink?
We would recommend that the product Bar Keepers Friend should be used. This should be sprinkled onto the sink and scrubbed into a paste with a stiff nylon short stubble nail brush, before thoroughly rinsing off. Bar Keepers Friend is available at from large supermarkets and hardware stores, and is also available to buy online from the manufacturer at www.homecareproducts.co.uk.
4/21/2010 5:07:15 PM •
Franke Home
Answered
on Apr 21, 2010
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
