20 Most Recent
Samsung SGH-J610 Cellular Phone Questions & Answers
Samsung spex cell phone
Press and hold for a few secs the # or the * key
(it should have a music note symbol with a cross) and that will switch
the phone from the Silent mode. Hope this helps.
Free unlock code for sgh-t528gsamsung sgh-t528g
Hapy New Year:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
How to STOP your Samsung Note 9 from constantly pocket dialing
OMG I finally figured out WHY my note 9 was constantly pocket dialing people. I tried so many things. This is what finally fixed it. It is a gesture setting. Open up settings. go to advanced settings then gestures.. Turn off Direct Dial. Direct dial is a setting that makes your phone call someone that you have been texting when you hold the phone to your ear. What happens is when you put the phone in your pocket it thinks you are holding it to your ear.
Insert sim e1220
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
Solution for samsung freeze phone
What is your SAMSUNG Model specify it correctly..You need to specify the current network and country it's locked now ..You can use UNFREEZE CODE to Unfreeze SAMSUNG Phone.You can get the Unfreeze code for samsung phones at
Theunlockarena.com/unlocking-services/rs13wp6/check whether Unfreeze service is available for your mobile's locked network and country ,if it's available you can get the unfreeze code here and unfreeze it.
How do i factory reset on my SGH-A847?
- While in standby mode, press the right soft key for Menu
- Select Settings
- Select Phone
- Select Reset Settings
- Enter the password, using the keypad
- If no password has been created, enter 0000
- Press the left soft key for Confirm
- Enter the password again to confirm, using the keypad
- Press the left soft key for OK
- Press the left soft key for Yes to reset the handset's settings to the factory defaults
Note: The device will power cycle to complete the restting. All device settings will be reset to factory settings.
How can i install spytic on my samsung 390
Now there are on the market freeware which the same thing and it's free. It is well worth a true lie detector.In addition, the GPS location function and spy call is free. You can even listen to all conversations.On hellospy.com you find can be the beginning of a response.
