20 Most Recent Samsung 46 in. LCD HDTV Questions & Answers
The power supply is failing.
Samsung 46 in.... | Answered on Jun 12, 2017
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Samsung 46 in.... | Answered on Jan 11, 2015
Most likely a broken backlight
Samsung 46 in.... | Answered on Jan 13, 2014
Yeah, you most likely have the same TV I do. I changed the capacitors and it kind of helped.. I discovered the problem is with humidy and rainy days! Is your TV near a window? I ordered a screen power inverter but just moved the TV upstairs and away from excessive humidy and its been fine ever since. I might still put the inverter in eventually.
GO TO A SAMSUNG SERVICE CENTER THEY WILL REPLACE FOR FREE DEFECTIVE CAPACITERS
Samsung 46 in.... | Answered on Jul 30, 2010
This could be 2 things, a main board or a power supply. I have replaced many main control boards on samsungs and it solved the problem. But sometimes it could be the power supply. You will need to test the voltages on the power supply to rule out the power supply being bad.
Samsung 46 in.... | Answered on Jul 11, 2010
no manuels are necessary the new panel will come with logic and ballast board already you only need to transfer main and power supply .
Samsung 46 in.... | Answered on Jun 10, 2010
all tvs are going to do that it is the difference between the two
Samsung 46 in.... | Answered on May 22, 2010
Take the tv aparts check the power board for bad capacitors,puff up or burst open.Replaced these capacitors.U know how to solders right?Or tries Shopjimmy.com,Ebay.com to buy refurbish power board.
Samsung 46 in.... | Answered on Jan 11, 2010
I bet they replace everything else but he LCD panel itself, you will see mor line as time goes by.
Samsung 46 in.... | Answered on Nov 05, 2009
I am confused here!
if the studs (vertical parts of frams) are 40" apart and the noggins ( spreaders are say every 20" )
Why are you trying to find them at 16 and 24?
Is there some cultural labnguage difference here about what a stud is?
An alternate fix rather than 100 holes in the wall is to use butterfly bolts ( expander bolts) these can hold up to 150Kg in any veneer wall
If nescessary drill extra holes in the frame of the TV haqnging frame4 to add more expande4r bolts into the wall
Samsung 46 in.... | Answered on Sep 07, 2009
Attach finished 1x4s to the two studs. Attach telelvision bracket to the 1x4.
Samsung 46 in.... | Answered on Dec 28, 2008
That's really odd that a power outage did that. I would try unplugging the TV, hold the power button for 10-15 seconds and then leave it unplugged for an hour and come back and try it again, that will for sure reset everything by removing power from it. If that doesn't have any effect then its possible the mainboard got damaged by a surge.
Samsung... | Answered 20 hours ago
Samsung 46 in. LCD HDTV Logo
32 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
green picture
  • Televison & Video
