20 Most Recent
Haier HL37E 37 in. LCD TV Questions & Answers
Green power light comes on but screen is black
could be 1 of many problems.first does it come on for a split second
then cut off?if so probably the inverter board.second does it not power
on at all?id ay that was problem with the power board.look for buldging
capacitors on the board.and ones buldging,replace with like kind.simple
fix
Wont come on any more
Sounds like you have faulty power supply board that need to be replace in order to fix the problem
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM •
Haier HL...
Answered
on Oct 26, 2012
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat.
The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions.
I hope this helps. Please add a comment with the model of your unit for further information.
