20 Most Recent
Syntax-Brillian Olevia 252TFHD 52 in. LCD TV Questions & Answers
Lcd Olevia circuit board issues
Check for the standard voltages when the unit is on. The values may be marked on the circuit board. Standard voltages would be 5, 12, 24 and sometimes 3.3 volts. Other than that, the brand is pretty bad. Try and find the same set with a broken screen and try and make 1 good set out of 2 bad ones.
Works fine but turns off Sporadically
seems like the tv power supply is having some issues.. you might want to try leaving the television unplug over night.. and turn it on the next day .. if the tv still turns off by it self then try plug in the tv straight to the wall or try a power strip if the problem is still there.. then the television's power supply will have to be replace or repair..
There is a 3rd party repair center that is able to service Olevia televisions.. the service center is called Amergence Technology 866-965-3842 they could get you a repair quote..
My syntax led tv sle3293md wont start
Fault to its main board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Blue screen on my syntax lcd t v
Try disconnecting unit from power source for several minutes.
Before re-connecting power hold power button for 5 seconds and I hope this resolves your problem.
Tv manual LT26HVX
If you are looking for the operators manual, that can usually be down loaded from the manufacturers web site.
If you are looking for a service manual, I use
www.servicemanuals.net , You have to register and there is a fee involved for each manual you order, but you can download the service/schematic manuals for immediate use. They have an extensive library, but not everything.
Olevia 432 missing screws
ok take the tv in to the home depot hardware store..go to the aisle where the hardware nuts/bolts/screws are..need to look either in the metric stuff and have a service person help you find the right size screws.. they carry them there..lowes does also but they are a bit more expensive..
No signal on screen
Make sure in the setup menu that "Cable" is selected instead of Antenna or off air. then do a channel search with the cable box connected and powered up.
