20 Most Recent Sony Cyber-shot DSC-T700 Digital Camera Questions & Answers
The region has to be changed to US or UK. It is done with a special Sony adjustment software.
Sony Cyber-shot... | Answered on Jun 11, 2016
have you tried SONY tech support .
Sony Cyber-shot... | Answered on Jan 05, 2015
Do you really want a cable? It'll probably be cheaper to get a card reader (if you don't already have one).
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. And a card reader will work with your next camera as well.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Sony Cyber-shot... | Answered on Apr 15, 2014
Required USB/ AV cable part number is as follows:
183587512... CABLE W/CONN UNDER 1000V
Available in Sony Accessories Store for $33
Sony Cyber-shot... | Answered on Aug 31, 2013
Start of Automatic Adjustment Program
Double-click the application file (DSC-T700 Auto-Adj
Ver_1.0r01.exe), and the Automatic Adjustment Program will start.
DESTINATION DATA WRITE
Note:
The DESTINATION DATA WRITE cannot be set with other
than the Service board.
1. Function of Each Button on Destination Data Write
Screen
Click the [DESTINATION DATA WRITE] button on the Main Menu
screen, and the “DESTNATION DATA WRITE” screen in Fig. 6-
1-10 will appear.
Fig. 6-1-10
1 [To Menu] button
Return to the main menu.
2 Destination Check button
Current destination setting checked when the “DESTINATION
DATA WRITE” screen started is displayed.
When this button is clicked, the destination is checked and the
display is updated.
3 Destination List
Select the written destination.
4 [Data Write] button
Write the destination data to the camera.
Japanese
English
French
German
Spanish
Italian
Portuguese
Simplified
Chinese
Traditional
Chinese
Dutch
Russian
Korean
Persian
Arabic
Thai
Melayu
Swedish
Norwegian
Danish
Finnish
Polish
Czech
Hungarian
Turkish
Greek
J1 J z NTSC
JE3 JE z a a a a a a a a a a PAL
U2 US z a a a a a NTSC
CA2 CND z a a a a a NTSC
CEE2 a a a a a a a z a a a a a a a a a PAL
CEE8 z a a a a a a a a a a a a a a a PAL
CEE9 z a a a a a a a a a a a a a a a a PAL
CEH UK z a a a a a a a a a a a a a a a PAL
E15 z a a a a a a a a a a PAL
E32 z a a a a a a a a a a PAL
E33 a a z a a a a a a a a NTSC
TH6 Thai a a a a a a a a a z a PAL
AR2 AR a a z a a a a a a a a NTSC
AU2 AUS z a a a a a PAL
HK1 HK z a a a a a a a a a a PAL
CN2 CH a a a a z a a a a a a PAL
KR2 KR a a a a a a z a a a a NTSC
BR1 BR a a a z a a a a a a a NTSC
z: INITIAL LANGUAGE
E
DESTINATION
VIDEO OUT
Default
AEP
AREA
SELECTABLE LANGUAGE
Sony Cyber-shot... | Answered on Oct 03, 2012
If possible, transfer to Dropbox
Sony Cyber-shot... | Answered on Jul 26, 2012
yea thers a password reset no. on the last few pages of ur camera manual. its a 4 digit pass unlock no. i also hv t700.
sorrypuja@gmail.com
Sony Cyber-shot... | Answered on Apr 02, 2012
Let's try Initializing the Camera.
If you're able to access the Home Menu select the SETTINGS in the Home menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize option under the MAIN SETTINGS to initialize the Camera.
If the issue still persists try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is required.
Sony Cyber-shot... | Answered on Oct 12, 2011
I'm sorry for the difficulties you're experiencing in copying images from Internal Memory to the Memory Card. Unfortunately, COPY option is not available in DSCT700.
You may connect the Camera to Computer after removing the Memory Card to transfer images from Internal Memory to Computer. And then insert the Memory Stick and transfer back to Camera to copy the images to Memory Stick.
Only few Cameras do not have the COPY option. Unfortunately, you're one of the victim.
You can confirm the information from the Handbook of the Camera.
Click hear to download the Handbook for the Camera.
Thanks for understanding. Please let me know if you require any clarifications.
Sony Cyber-shot... | Answered on Aug 06, 2011
Many sources (reviews) of this specific model suggest that the camera has focussing issues, not just at close range. It does seem to be subject dependant though. Many cameras need a good degree of contrast around a centre point of the subject to focus properly. Bear in mind that this model was released in 2008, and technology (i.e. later models) has improved since then.
Just one example that states what most other sites also state, can be found here: http://www.imaging-resource.com/PRODS/T700/T700A.HTM
Sony Cyber-shot... | Answered on Jun 11, 2011
Title: Language change in cyber shot
Turn on camera.
Click on the Menu button.
Scroll to Setup, it's the last one.
Scroll down to Setup 1, first tool box icon.
Scroll down to the 3rd menu.
Choose English from the list.
This is from an H2. If they are different, go to sonystyle.com to download an English version of the Users Guide for instructions.
Sony Cyber-shot... | Answered on May 13, 2011
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sony Cyber-shot... | Answered on Apr 05, 2011
C:32:01 is a "disk format error". It means that your memory card is most likely corrupted.
First, remove the memory card and visually check that the electrical contacts are bright, clean and not greasy. Do not touch the contacts with your bare skin, use a cotton bud moistened with alcohol or methylated spirits if they need cleaning. At the same time, check that the lock switch on the MemoryStick is fully unlocked. Slide it fully to locked and then fully back to unlocked.
If the contacts and lock switch are fine then you can try reformatting the MemoryStick using the "Format" command in the camera menu, do NOT do this on a pc/Mac or in an external card reader. If there is an option to "Full Format" or "Quick Format" choose the full option. Note that any stored images will be deleted, but if you have suitable data recovery software they can still be recovered afterwards as long as no new pictures are taken which overwrite the data.
If that fails then try another MemoryStick in your camera. If the fault remains then the camera is faulty and must either be sent to a Sony Service Centre or replaced. Your camera may still be under the manufacturer's warranty, if so repairs will be free.
I hope that I have been of some assistance; please take a moment to rate my answer.
Sony Cyber-shot... | Answered on Feb 06, 2011
Home > Last Option (looks like a bag) > Language Settings > Ok > Click on the only option > OK > And then finally choose your language.
Follow these steps so you'll get there,
- > IF YOU NOT HAVE THE "HOME" OPTION ON YOUR LEFT UP CORNER , THEN CLICK ON "DISP" ON YOUR RIGHT DOWN CORNER AND THEN FINALLY CLICK ON "NORMAL" , THERE IT IS, SIMPLE AS 1 , 2 ,3 =)
I hope I answerd your question.
Sony Cyber-shot... | Answered on Jan 21, 2011
Ok here we go... Click on "home" then go to the fourth option with the Memory Stick picture and click there... click on the only option called Memory Tool and then OK and finally click on "Copy" and then click on Ok and then Ok again... thats it.
I hope I helped in something.
Hi, so here we go... If you have the optiong "Home" on your left up corner then click it, if not then click on DISP. on the right down corner and then click on "Normal" and close it, Ok, now click "Home" then the last option that has an image that looks like a Bag, click on "Main Settings" click Ok, click on the First Option of the Second Line called "Initialize" and thats it, it will turnoff and on by itself and you'll have to set the date and time again.( there are some problems that wont fix with that option, but I wish you luck )
I hope I helped with something.
Sony Cyber-shot DSC-T700 Digital Camera Logo
86 questions posted
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
buy s3300 cable transfer pictures
  • Cameras
