20 Most Recent RIM BlackBerry ® 8830 Cellular Phone Questions & Answers
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
RIM BlackBerry ®... | Answered on Jan 13, 2017
What's your Exact Blackberry phone model?You can get unlock code for your Blackberry phone from UnBBLock.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.
RIM BlackBerry ®... | Answered on Mar 24, 2014
Hi if you want to unlock your Blackberry 8830 mobile from network lock .Then visit Mobile-Unlocker.com here they are providing unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ....
RIM BlackBerry ®... | Answered on Feb 25, 2014
Are you referring to network lock,If so you can remove it using unlock code... you can get such code from any vendors online like
SimpleUnlocking.com
RIM BlackBerry ®... | Answered on Jan 10, 2014
Stop Nokia Lumia Music Player...
Watch solution at forllowing youtube video:
http://youtu.be/uTyhAdTJMpI
RIM BlackBerry ®... | Answered on Sep 07, 2013
I think my boyfriend is cheating. he has his blackberry 8830 on lock. I do not have the code. How would I unlock it??
RIM BlackBerry ®... | Answered on Apr 24, 2013
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
RIM BlackBerry ®... | Answered on Sep 22, 2012
To Unlock Blackberry Bold 9000 use unlock code..Visit the site Simpleunlocking.com get unlock code and get free Unlocking instructions at Mobileunlockguide.com/blackberry-bold-9000 and unlock it from network lock step by step.
RIM BlackBerry ®... | Answered on Sep 13, 2012
As far as i know free unlock codes doesnot work properly.please donot use wrong codes its damage your phone.i am saying this because my friend lost his phone by this.i know the site from where you get your unlock code.its not free but it as much cheap as free.click here to get your unlock code.
hope this helps..
RIM BlackBerry ®... | Answered on Jun 26, 2012
Hey you can unlock your Blackberry 8830 using the codes.I found an unlocking service at Classicunlocking.com which offer the service for your mobile.With the help of this you can unlock your mobile easily.
RIM BlackBerry ®... | Answered on Jan 11, 2012
Your Blackberry 8330 locked to which Network?
You can unlock it easily using the unlock code,get that Unlock code from the site Onlinegsmunlock.com
and Unlock it step by step.Then use any GSM Sim card.
RIM BlackBerry ®... | Answered on Dec 28, 2011
Good Day,
Please check your network settings. Go to MENU>MANAGE CONNECTIONS>MOBILE NETWORK OPTIONS There you will see:
Data Services > which should be "ON" Mobile Network> your providers name Network Selection: >Should be automatic Network Mode: > depends on your network provider(CDMA or 1xev on most North american networks)
just check these settings specially the Data Services that should be on, just click on it to turn on. Also the network mode should be correct.
Lastly you may check with your subscription, If you have a subscription plan on your network that supports Data services. You may want to call your provider with this settings. Specially the BIS subscription. They would be just happy to help you with that in case it is not yet activated.
Hope this helps you. Thank you for using Fixya.
RIM BlackBerry ®... | Answered on Dec 13, 2011
Looks like you just change your original sim card with other network sim card. You must unlock your blackberry first before you can using other network in your phone. What you need is blackberry 8830 unlock code from your original phone network sim card. You can get blackberry unlock code from network provider or buy from third party sites which have lower cost rather than network provider.
RIM BlackBerry ®... | Answered on Sep 06, 2011
RIM BlackBerry ® 8830 Cellular Phone Logo
154 questions posted
Top RIM Cell Phones Experts
RONALD CARTER JR
gggg
Ekse
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
BlackBerry RIM
  • BlackBerry RIM
Most Popular Question
gprs network will show
  • Cell Phones
