20 Most Recent LG WM-2032H Front Load Washer Questions & Answers
damper is stiff. i would look at the springs that hold the tub if you take them off a bad one won t close all the way up also check leg mounts for weak medal
LG WM-2032H... | Answered on Mar 02, 2018
Sounds like all you need is a new pump motor. Pretty common issue. Fairly inexpensive motor. About $30+ on amazon. Check out repairclinic.com or appliancepartspros.com for part numbers and repair videos. Good luck.
LG WM-2032H... | Answered on May 01, 2017
is it getting enough water in tub? try extra water button and see if then it works. if that makes it work, then water pressure sensor may be an issue
LG WM-2032H... | Answered on Apr 02, 2015
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
LG WM-2032H... | Answered on Mar 29, 2014
You have a tub "Balance" bearing that is Shot! Goner! Dead! And your Tub may be a goner too! Depending on the extent of damage, you said you saw SMOKE! I never seen smoke from a washer unless someone throws a Concrete Block Stone in one on You Tube! ON PURPOSE! You have to weigh the age of machine vs the price of a new/USED one. If your machine is over 7 years old. Get a new One! Not a LG for goodness sake. Get a Whirlpool or a Maytag. I just bought a used one (Whirlpool) for $150. Still works 2 years later right next to the Dead $1600 LG I bought 6 years ago! The man I bought it from is in Rosamond, Ca. right by Edwards AFB. He has a garage full of them and guarentees his machines. There are a lot of people that do this. New is Not always the best!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
LG WM-2032H... | Answered on Dec 27, 2013
see the causes and fix it. Use the common sense. God bless you
If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
LG WM-2032H... | Answered on Sep 23, 2012
Please check this link for tip : click on : dispenser
LG WM-2032H... | Answered on Jun 28, 2012
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
LG WM-2032H... | Answered on Mar 01, 2012
Hopethis helps.. A 4 thumbs-up rating is greatlyappreciated for answering your free question. Thank you in anticipation.. Good luck! ;)
LG WM-2032H... | Answered on Jun 10, 2011
I believe you may have put it in the second largest container (Usually marked by a bucket with a 1 in it), this is for Pre-wash. So you will have to select Pre-wash on the Facial panel. It will then take the bleach first and after washing with it, the machine will rinse and drain it away - and continue with the normal wash and whatever you may have also left in the detergent box.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up, and a testimonial will do nicely :-)
LG WM-2032H... | Answered on Apr 03, 2011
Open the access door at the lower left on front of the machine. Use the hose there to drain the water out of the machine. Unscrew the big knob there and pull out the attached filter. Clean out filter and replace. If filter was clear, replace drain pump motor.
LG WM-2032H... | Answered on Mar 06, 2011
At this point, replace the pump motor.
LG WM-2032H... | Answered on Mar 05, 2011
That is what is probably wrong. It is better just to buy a new one Alan.
LG WM-2032H... | Answered on Feb 26, 2011
possible hall sensor failed here is a forum on that
http://appliancejunk.com/forums/index.php?topic=1735.0
LG WM-2032H... | Answered on Dec 25, 2010
needs new bearings relaced
LG WM-2032H... | Answered on Dec 01, 2010
LG WM-2032H Front Load Washer Logo
53 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
pe errors lg washer wm2032hw replaced
  • Washing Machines
