20 Most Recent Schiller Cardiovit At 2 Light Ecg Machine Questions & Answers
No can do. Cm is distance and Kg is weight. Inches are distance and pounds is weight. Thats like "how can I convert an orange into an apple. RJ
Schiller... | Answered on Sep 29, 2017
Convert inch pound to kg cm - Conversion of Measurement Units
www.convertunits.com/from/inch+pound/to/kg+cm
Quickly convert inch pounds into kg cm (inch pound to kg cm) using the online calculator for metric conversions and more.
Schiller... | Answered on Jun 08, 2017
Try this link to slide share for a colour rendition of the user manual
http://www.slideshare.net/DiscountCardiology/schiller-at-2-ekg-manual
Schiller... | Answered on Apr 17, 2015
Likely your paper is loaded incorrectly or is incorrect for the unit. The auto print format depends on the position of the black "que" mark in the paper, but the manual mode does not. Be certain that the paper is correct for you unit.
If that isn't it, then you que sensor could be dirty or defective. THis would require shop level repair, as dis-assembly of the unit is required.
Sounds like you need a new battery. When they go dead you will still see the green light but it will not turn on or only on for a second.
To change the Time :
- Firstly, press the following key sequence : ALT, 9, 1, 1
- Then, enter the time (HHMMSS)
- Finally you'll hear the confirmation beep
To change the Date :
- Firstly, press the following key sequence : ALT, 9, 2, 2
- Then, enter the date (DDMMYY)
- Finally, you'll hear the confirmation beep
Schiller... | Answered on Sep 26, 2013
hi,
Your machines thermal printing head have some problem. Thats why it give printouts very light. Not possible to repair thermal head. You have to replace it.
ok
Schiller... | Answered on Dec 13, 2011
Greetings. The schiller AT2 is battery powered. It will power on when plugged in however even with a dead battery, but if the battery is REALLY bad, we have seen it load the power supply preventing power up. On the top of you unit there is a small green "AC" indicator that should be illuminated when the at2 is plugged in. If it doesn't, your power cord might be bad, try a new one. If that doesn't fix your problem I would try at least to replace the battery. The battery requires dis assembly to replace, and there are three cable attaching the top case to the PC board. If you pull it apart to far without detaching the cables, you will do expensive damage. Also the removal of top case exposes high voltage, so this should never be undertaken a. with the unit plugged into a wall outlet, or b. By an unskilled individual. I would recommend that you find a local bio-medical contractor, or other service company, and have the battery changed. If your chosen contractor replaces the battery and the problem remains, your main board likely needs replacement, again by a qualified individual. Be warned however this in a very expensive part. There are several other possible problems, but very few that are operator serviceable. Best of luck!
Schiller... | Answered on Nov 21, 2011
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
Schiller... | Answered on Jul 19, 2011
hi,
check the paper you have inserted. if the paper quality is bad then the printing can become bad. Use schiller original paper.
if again printing is bad then the thermal printing head of you machine is faulty or the. you have to replace the same.
ok
Schiller... | Answered on Apr 18, 2011
Have you selected the right program?
Schiller... | Answered on Mar 05, 2011
hi,
there is a pressur adusting facility inside for the thermal printing head. u can adjust it for quality printing. for adjusting the same i will prefer use the help of a qualified person.
ok
Schiller... | Answered on Dec 23, 2010
1001 Questions I could ask to solve this dilemma but one will do, manufacture and model please?
Schiller... | Answered on Mar 16, 2010
I think I have the user guide for this. please send me an email and I will send it over to you. wats@mesasales.com
Schiller... | Answered on Oct 26, 2009
Hello medico001, The info on the Schiller web site states an option of 12 lead for model Cardivot AT. If your unit has this option only the automatic selection will deliver the 12 lead print. For futher info select the web site http://www.schilleramerica.com and click on 'Contact Us'. This should direct you to someone local. Good luck.
Schiller... | Answered on Nov 04, 2008
This is due to a hardware error. You need the support of the vendor.
Schiller Medical | Answered on Jan 11, 2018
6 lead / 12 lead EKG. It is unlikely that you can do that with your machine. 6 leads are rarely used and would require a totally different internal format. 12 lead Ekg is the standard of care. Chose 12 lead and dont worry about finding a 6 lead. RJ
Schiller Medical | Answered on Sep 28, 2017
Schiller Cardiovit At 2 Light Ecg Machine Logo
32 questions posted
Top Schiller Medical Experts
Jim Goldsmith
Jim Goldsmith
Andrew Taylor
Andrew Taylor
Are you a Schiller Medical Expert? Answer questions, earn points and help others
View Most Popular
Schiller Medical
  • Schiller Medical
Most Popular Question
schiller 2 in office acting
  • Medical
