20 Most Recent
Gardner Bender GVD-505A Non-Contact Voltage Tester with Pocket Clip Questions & Answers
Testing amps with a gb GDT 294a
you need to connect your unit in DC Amps mode in series with charger when in use BUT be careful that anything over 10A will blow the fuse
How to set GDT-311 Digital Multimeter to x 1000 ohm setting?
The 20K setting is close to what you're looking for. The 200 scale is best to read 0 to 200 ohms, the 2K setting would be to read 200 to 2K, the 20K is to read 2K to 20K, the 200k range is for 20K to 200K and finally, the 2000K is to read 200K to 2000K or (2M) ohm resistance.Basically, start on the high range, and work your way down until there is only one (or none) digit after the decimal point in the display for the best accuracy. A 6,500 ohm value may display as .006 reading on the 2000K range, and as you can see, doesn't give a true reading of the actual value. I hope this helps!
