Troubleshooting & Support
Hot Topics:
- making ice
- Ice dispenser...
- lg lrsc
- dispenser
- remove ice...
- ice tray
- not making ice
- lrsc26925tt ice...
- water dripping...
- water filling...
- water button...
- change filter
- water ice maker...
- freezer fan
- ice dispenser...
- parts
- water leak...
- water dispenser...
- ice maker not...
- er ff code
- ice dispenser
- water dispenser
- er dh
- lrsc26923tt
- 26923sw
- water filter
- autolock...
- er ff
- ice chute
- freezer door...
- View All »
Problems & Solutions
Water will not dispense. Will not make ice. Maybe
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in...
Water leak in fridge.
The most common cause is ice built up and plugged thedrain hole as non Auto defrost in time. Unplug the power de-ice. Locate the drain hole....
The water dispenser is really
water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated,...
The ice and/or water won't stop coming out the
It sounds like the actuator for your dispenser switch is sticking. To fix it you will need to get inside the dispenser housing, which...
display reads er and ff
Hi Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan...
My freidge stpo working,all i see on the digital
this fault code means that the evapoator fan motor (the one in the freezer compartment is faulty) the electronics detecting possible open...
special sound comes from back side. after that no
pull unit away from wall look for fan that cools evaporator coils see if its running check to make sure nothing is obstructing movement
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the...
water/ice dispenser sticking on
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the...
Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure DH= defrost heater Defrost heater, temperature fuse short circuit, unplugged connector(indicated 4 hour...
lg refrigerator water dispenser would not shut off
so two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the...
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is...
code Er dH
Indicates Poor Defrosting. This error occurs when defrosting sensor is not over 8 degrees C an hour after defrosting. Possible causes are...
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
How do you replace the dispenser funnel on an LG
funnel itself squeeze in on sides to release tabs. so many tabs broke a redesign was made 5-30-2005 , have to replace frame bracket and...
Unsolved Problems
Ice and water dispenser light turns on and off...
Ice and water dispenser light turns on and off when freezer door is closed. There is also a clicking sound coming from...
how to remove the dispenser panel
Need to replace the button assembly
How to proceed to level a side by side LG...
How to level
LG light control assembly melted by bulb
Pulling out the light control assembly in the refrigerator to see if I could detect the source of the constant clicking...
LG ice maker flap not opening
Pulled solenoid, very hot...the plastic arm from the flap assembly was melted...not nice.
lrbn20510ww buzz or beep noise
started getting a buzz or beep about every 5 minutes. So far fridge is working fine.
water leaking onto floor from the front water line
water leaking onto floor from the front water line to ice maker
Manuals & Guides
TopDo you have a manual for LG LRSC-26922 Side by Side Refrigerator? - Upload it to FixYa!
Upload a manual for LG LRSC-26922 Side by Side Refrigerator
Specifications
TopKey Features
Full Product Name:LG LRSC-26922 Side by Side Refrigerator
Type:Side by Side
Total Volume:25.5 cu. ft. / 722 liter
Total Number of Shelves:3
Fresh Food Compartment
Door Opens:Opens to Left and Right
Dimensions
Overall Depth:35.25 in.
Overall Height:69.75 in.
Overall Width:35.75 in.
What's your problem?
Fix-O-Meter
32,012
32,012 people have viewed this product
- 274 people asked about this product.
- 89 people found solutions for this product.
- 6 people have added this product.
Pins on the...
How to fix your...
Ice Maker...
