20 Most Recent Powerfast Stanley TR110 Light-Duty Staple Gun Questions & Answers
Are you loading it correctly? It took me awhile to figure it out myself. When you pull the clip out I was convinced you have to load them in there above where that black spring is on the slide lock that you pull out (as they seem to fit there) but no, you do have to turn it upside down to where the place where the staples shoot out is facing you and then load the staples into that space that you now see in front of you by placing the staples in upside down (pointy ends facing you). Then just slide the slide lock back over the staples you just placed in. I had to push down and then up on the clip to lock mine in all the way but some might lock in on their own (not sure). It should work fine from there.
Powerfast... | Answered on Jun 26, 2016
This doesn't load like normal staple guns. Go to the end of the stapler and pull out the locking device with the spring on it. Then turn the staple gun upside down so you're looking at the bottom of the gun. See, there is now a little channel exposed. Drop the staples in this little channel with the points of the staples pointing towards you. Keep the staple gun upside down and reinsert the locking device which will compress the staples. PRESTO! Ready to use.
Powerfast... | Answered on Nov 18, 2012
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Powerfast... | Answered on Jan 16, 2012
Have you looked at the spring for possible loss of pressure.
Powerfast... | Answered on Mar 05, 2011
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
Powerfast... | Answered on Mar 01, 2011
http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-2652138769159946669/view_document!PAGETYPE?sq=Stanley%2bTR110&sc=2&sf=101113&sg=1&st=6673&documentid=336954&action=view
your manual is here!!
your welcome.....
Powerfast... | Answered on Feb 15, 2011
there is a lever on the back that you need to pull down in order to load the staples,, now it is spring loaded - so you will need to depress it and slide it back to reveal the chamber.
c...
check the spring,. also there must be something lodged in it... look closer..
Ck
Powerfast... | Answered on Feb 13, 2011
This gun uses the T-50 style staples. It uses Heavy-Duty, Narrow Crown Staples.
Powerfast... | Answered on Jan 06, 2011
Powerfast Stanley TR110 Light-Duty Staple Gun Logo
37 questions posted
Top Powerfast Tools & Hardware - Others Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Powerfast Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Powerfast Tools & Hardware - Others
Most Popular Question
stanley sharp shooter tr110 staple
  • Tools & Hardware - Others
