20 Most Recent
Porter Cable Porter-Cable 7301 5.6 Amp Replacement Motor for 7300 Series Laminate Trimme Questions & Answers
I have a 7301 power unit, 7309 trimmer base, 7311
first things first, the lock pin has a spring that is supposed to push it away from the shaft after using, if it is not releasing there could be a burr on the shaft/pin or the spring might be missing. the electrical smell can be from the field or armature and the freezing up might be a bearing which can lead to that smell. I would suggest going to "dewaltservicenet.com" and you can download the owners manual/breakdown for this tool. I think that I saw list price around 63.00 for the trimmer so I would not put a lot of money in the repair. They are not that hard to take apart so let me know if you need more assistance and I will try and help
I have a PC Model 136 Belt sander--I know it's
I also have a PC Model 136 belt sander. Although I don't do a lot of woodworking, it has proved to be a workhorse when I needed it. I don't have a problem with breaking belts - the last ones I bought at OSH. The problem that has developed with mine is getting the belt alignment adjusted, after a belt change, to not run against the sander body. A little banging (with my hand) will correct the problem. I have serviced it to free up the fulcrum, but it still jams most of the time.
This doesn't address your problem, but it is good to hear of someone else who appreciates the fine older tools.
Just a further thought - the newer belts I have purchased are bi-directional, e.g., they will run either way. I know that the older belts had to run one way and running them backward could - almost surely would - cause them to break. I won't insult your intelligence to suggest that that might be your problem.
How do i take apart a model 7812 porter cable vacuum to change brushes
The brushes are not replaceable - it is an entire motor assembly.
1) remove the 2 screws holding the top handle on
2) remove the 2 screws on the top of the housing (front either side of switch)
3) remove single screw holding cord hook (rear side of housing)
4) remove small torx screw in the shaker handle and remove the handle
Flip over and using a screwdriver begin to pry the top cover off the housing (easiest to get the front side off first)
Rust in air compressor tank
first you need to remove the tank and get rid of the rust with a rust kill agent, vinga or chemical type with corrosive converter, then liquid paint the inside of the tank, swilling the paint inside and leave to drip out. then find a high pressure line filter, these are a solid filter and put in line. to stop this happening again to the tank you can also put a drop valve in place and when not in use press to release the air inside as this is what rusts the tank. but after the restoration it should be fine without a filter.
How do I unjam a porter cable BN200SB nail gun
I suggest that you make sure that there is no air he tool so, remove the air supply. Then if you remove the cover from the nose (Making sure that you also take out all the unused nails first) it should allow access to the front nose plate. If you remove this, it will allow you to carefully remove the nail. While you're at it, check that the driver blade tip doesn't have any burring or damage to it. If so, you might need to fettle it back into shape or, replace it?
Parts for a 335 sander (6
Part is no longer produced. I am going to adapt a 6" dewalt pad by drilling new mounting holes. (The Dewalt pad has 4 holes.)
