20 Most Recent Vector Maxx SST Power Inverter Questions & Answers
2answers
I have to power 1800
I think the problem might be your battery setup.
First of all, these batteries are not deep-cycle batteries they may not tolerate this kind of usage. Secondly, if you have 20 batteries connected in parallel they could end up working  against each other (draining each other) all the time.
You might do better with 2 very large 6 volt deep-cycle golf cart or fork lift batteries.
1/23/2013 11:08:06 PM • Vector Maxx SST... • Answered on Jan 23, 2013
No led red or green vec550pob 1500 watt, nor do i
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
2/2/2011 2:10:51 AM • Vector Maxx SST... • Answered on Feb 02, 2011
I have to connect a busser across a inverter such
What kind of buzzer do you intend to use? Have you already selected a particular buzzer? The circuit depends on buzzer type / voltage rating / current draw.
Are you wanting the buzzer to be on the AC side of the inverter, or on the DC side? Is the buzzer going to be close to the inverter, or will it be placed some distance away?
6/26/2010 3:34:23 PM • Vector Maxx SST... • Answered on Jun 26, 2010
I plugit in and turn the inverter box on, one
The problem you are experiencing is as
a result of an overload.Your inverter is
200watts and i believe your freezer has
a higher power than it, i.e.it is above
200watts. When ever there is an
overload on an inverter it distroys the
power transistors that make the
inverter work.You will need to see a
local repairs person.
5/10/2010 12:48:04 PM • Vector Maxx SST... • Answered on May 10, 2010
3answers
Problem with getting inverter to work...
Inverters works from 12v carr battery or backup battery, you can not charge the inverter you msay killed your inverter if you connected to 120v wall mount...you use the inverter to give you AC (electric) from 12v battery. if your tv is 12v you need to know how much needed to get the correct connrection as output and input.
5/7/2010 10:27:13 PM • Vector Maxx SST... • Answered on May 07, 2010
2answers
Power cord missing
These cords are sold at Walmart.
Or you can go to your local auto parts store and make a set.
Hope this tip helps.
r/
David
5/7/2010 10:25:31 PM • Vector Maxx SST... • Answered on May 07, 2010
I CANNOT FIND A REPLACEMENT FUSE FOR THE VECTOR
Go to any Appliance parts store with your fuse in hand and walk out with a replacement. The 250V fuse is AC OUTPUT and "not" a DC input fuse. That is an 8 amp 250V slow blow fuse.
3/26/2010 3:36:39 AM • Vector Maxx SST... • Answered on Mar 26, 2010
When wiring reversed polarity. now it not work. is there fuse in the unit some where?
Fuse is there, but more damage is suspected. Transistors damage easily and capacitors will short when subjected to reverse polarity.
1/1/2016 11:44:39 PM • Vector... • Answered on Jan 01, 2016
4answers
What can i hook up with 1500 watts
15 100watt bulbs
1/4/2015 3:45:23 PM • Vector... • Answered on Jan 04, 2015
Durite inverter
If the unit doesn't have an external fuse and it doesn't reset itself after an overload, it possibly has an internal (onboard) fuse that needs replaced. Possibly de-soldered and re-soldered...
2/2/2014 5:57:01 PM • Vector... • Answered on Feb 02, 2014
0answers
Tvec034 manual
Be the first to answer 9/3/2013 5:17:14 AM • Vector... • Posted on Sep 03, 2013Be the first to answer
Vector Maxx SST Power Inverter Logo
23 questions posted
Top Vector Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Vector Electronics - Others
Most Popular Question
power 1800
  • Electronics - Others
