20 Most Recent
Deadbolt Electronic Keyless System - Bright Brass Questions & Answers
Rona collection door lock
I Bought a Rona keyless door lock about 10 years a go.It is broke its life time warranty. where can I get it replace.
6/28/2021 3:40:58 PM •
Deadbolt...
Answered
on Jun 28, 2021
I bought Rona Collections Electronic Deadbolt. My
You must ensure the deadbolt is in the locked position when attaching the control mechanism. The control mechanism must also be set to the locked position. Turn the manual knob to the left then attach the mechanism (with the batteries) to the flat pin. You can do all of this with the door open, so you can enter the codes. My initial install created the same issue. It worked properly out of the package, so that meant that I screwed something up. You don't need to return the item. Just do a little fault finding.
7/11/2015 3:39:46 PM •
Deadbolt...
Answered
on Jul 11, 2015
Resetting Master pin on rona Electronic Deadbolt lock
GoogleRona Electronic Deadbolt Lock Instructions:Default Master Code:123Resetting Master PIN:Remove batteries and put them back. You will hear a long beep and a short beep.Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.Adding a PIN:Key in master PIN and press UNLOCK buttonPress and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.Release 0 button and you are in the Add PIN modeWithin 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.make model resetting lock
https://www.google.com/search?q=resetting+Master+pin+on+rona+Electronic+Deadbolt+lock..
I had to replace my batteries in my electronic deadbolt and now it won't let me reset the code and I've followed the directions and not working
You didn't say what brand or model, so here's a generic answer:
Find the instructions to reset it to factory codes. Sometimes this is as easy as removing the battery and waiting an hour (or a day) and other times you have to enter special codes, or disconnect a jumper, or connect 2 points with a wire to erase the codes. Once you have the lock reset, put brand new batteries in and follow the instructions for programming a brand new lock.
If you don't have the instructions, you can often find them online by entering the brand and model # into the search box of Google or YouTube along with a word or phrase like "instructions" or "manual" or "getting started."
