20 Most Recent Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Questions & Answers
I'm a little confused here. First I see a problem with Homelite 9.0 amp chainsaw, then you ask about an Electromac EM 200. Both of those are electric saws and don't require a "mix". The only thing you have to put into them is bar and chain oil.
Homelite... | Answered on Nov 06, 2018
you have to adjust the air and gas intake
Homelite... | Answered on Oct 04, 2015
Rebuild or replace carb.when they sit with gas in them the oil in the gas can plug them up.
Homelite... | Answered on Jan 19, 2015
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Homelite... | Answered on Sep 15, 2014
The best idea is to top it off when you fuel up.
Homelite... | Answered on Jul 22, 2014
You buy a bottle of 2 cycle mixing oil for your saw. The directions on the label apply to all mixes. it does not matter the size of the saw.
Homelite... | Answered on Apr 21, 2014
It states your saw as an electric saw. So no you don't even add fuel.
Your power comes from electrical power.
Homelite Chainsaws have no brushes that I know of. Maybe it is not that. It could be a short in the magneto coil wire that goes to the switch.
Check to see if anything is shorting out under the flywheel cover.All the way back to the switch.
Hi, poppa530 I will try to help you out. You probably installed the chain so it is not engaging the sprocket. Remove the chain and re-install, but make sure it is engaged on the sprocket located behind the drum where the shoes are that as the RPM goes up engage the drum and turn the chain. I can't think of anything else that could be causing this problem, unless the drum and clutch shoes are not engaging any more. Do you know if the clutch shoes, drum and sprocket have been removed from the crankshaft, and maybe not re-installed properly? Can you turn the chain by hand? If not, something has jammed preventing chain from turning. Have you recently installed a new chain, bar or both? If so, you might not have the right width drive link tang or the right pitch on the chain. If a new bar has been installed the bar groove might not be the right size. You might also check out the sprocket to see if it is bent or damaged. I hope I have helped even a little bit. All the best and good luck. Any questions welcome.
Homelite... | Answered on Apr 01, 2014
You will need to take the recoil assembly off the saw and wind the cord springer tighter around the pully as needed to take up the slack. There should be a notch in the pully you place the rope in and turn the pully in the direction needed to wind the spring tighter a turn or two. Then take the rope out of the notch and the slack will be taken up by the spring.
Homelite... | Answered on Jan 27, 2014
In my dealings with electric chainsaws if you try to cut wood too big in diameter the electric motor burns out and you will net to replace the saw
Homelite... | Answered on Nov 21, 2013
The original Homelite company has been out of business for many years. Getting parts for them at our repair shop is impossible. I know you can go and buy new Homelite units from the big box stores, but these are not being manufactured from Homelite. Sometimes you can find parts from repair shops that have leftover parts. You might want to call around. You might find them. George
Homelite... | Answered on Oct 21, 2013
The "ONLY WAY" fuel can pour out the carburetor is because the needle is being held up off the seat inside of the carburetor. A piece of trash is most likely causing this. Remove the carburetor, disassemble it, remove the needle and blow compressed air into it to see if it will clear it out. George
I saw no Textron listed. An inspection of your saw will probably reveal a "UT-", that seems to be the key.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches. Good luck
Lou
Homelite... | Answered on Oct 08, 2013
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
202 questions posted
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
mculloch electramac em200 2 0 mix use in
  • Garden
