20 Most Recent Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Questions & Answers
These things can be very sensitive with how the sting is coiled on the spool. Take your time and try to get it perfect. Look at the pre strung replacement spools for an example. also inspect the lever, usually under where the spool sits. Make sure its not to dirty and moves freely. After that when you want it to feed quickly pull and release the trigger a couple times. If you dont want it to feed the when you pull the trigger be sure to maintain how far you have it pulled back, then release it a little slower than usual. Lastly wait a few seconds before pulling again. If this doesnt work the lever may be worn out and defective. But they are super cheap and easy to replace.
Homelite... | Answered on Apr 01, 2014
Remove the shaft and pull the drive shaft cable out and check to see if its broken or stripped at the ends.
Homelite... | Answered on Oct 30, 2013
Rebuild or replace the carburetors and change the fuel filters.
Homelite... | Answered on Oct 29, 2013
The fuel line in the tank connects to the nipple. It then goes into the small hole in the tank and then the fuel line from the carb connects to the nipple. This line is the line that is attached to the body of the carb, not near the plate.
You may have a broken drive shaft. Some are braided and flexable and used on curved shaft units. The solid shaft is used on most straight shaft units. Remove the string head and pull the shaft out to look at the ends to see if they are broken or stripped. George
The plastic stops are called limiter caps and they are required to be on there by EPA. You can remove them and make the adjustments and then put them back on.
Sometimes even if the diaphram and gaskets look ok they may not be. If the diaphram is stretched or distorted even a little they wont work properly,same for gaskets and other parts of the carb. sometimes the littlest things can make a big difference. I would try a complete rebuild kit and while everything is out of the carb. spray the carb real good and then lite-ly blow out the carb. with an air hose also if you take a twist tie from bread and take off half of the paper from the wire and carefully probe all holes in carb. that might do the trick for ya. After you put the high and low adjustment needles back in (if your zama carb. is set up with them) you'll want to set the low needle (after turning all the way in till it just bottoms) at 1 and 1/4 turns out and the high at just about 1and 1/2 turns out, then while running make final adjustments.
Look at the arrows printed on the outer cup...counter clock wise is the direction I believe
Homelite... | Answered on Sep 07, 2012
This is how a major diaphragm carburetor manufacturer suggests doing it:
http://www.zamacarb.com/tipspage.html
Homelite... | Answered on Aug 19, 2012
there are plastic caps on the adjustment screws they are there so you can't adjust them but if the fell off you can
Homelite... | Answered on Aug 11, 2012
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Homelite... | Answered on Jul 07, 2012
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
109 questions posted
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
keeps stalling out wont stay running
  • Garden
