20 Most Recent
Dynamo ABOVEGROUND POOL PUMP - 1HP - Questions & Answers
Pentair dynamo 340210 was running
you have probably hit a dead spot on the motor - try turning the motor by hand and then turn it on - maybe it will kick it.
dangerous to do it while the power is on but some people have had luck doing the same thing while the power is turned on.
US Parts Center
1/6/2018 6:45:24 AM •
Dynamo...
Answered
on Jan 06, 2018
How do i remove the impeller from a dynamo pool
WITH LOTS OF LUCK . THEY SCREW OFF(OFF TO THE LEFT LOOKING AT THE IMPELLER SO COUNTER CLOCKWISE ) VICE GRIP OR SCREW DRIVER ON SHAFT TO HOLD IT, THING IS IF THE SHAFT IS RUSTY YOU HAVE A REAL GOOD CHANCE OF BREAKING IT AND IMPELLERS CAN BE HARD TO FIND.. THE SEAL SHOULD BE # 1000 FOR THAT PUMP... BEST OF LUCK.. J
12/31/2017 6:53:29 AM •
Dynamo...
Answered
on Dec 31, 2017
My pump just quit today. It was running with the
it sounds like you may have an obstruction in the impeller. Is you pump basket cracked or damaged? You may have to pull the pump apart and check the impeller, clear the debris and you should be back up and running.
8/16/2010 4:30:28 AM •
Dynamo...
Answered
on Aug 16, 2010
When turned on the pump just has a buzzing sound
no its a sign of somthing stopping impeller take strainer out and check for sticks or something stopping it impeller iis in housing behind water cup may have to be removed try taking a pliers and turning shaft while pump is off this may free it
8/12/2009 10:18:01 PM •
Dynamo...
Answered
on Aug 12, 2009
Motor runs for 10 sec then kicks breaker off. dont
Short in the motor - It may be salvagable but not likely. Try a local electric motor repair shop but call first for labor charges. Some don't work on 'small' single phase motors. If it is not the winding that is bad expect to pay about $100 to fix it, assuming it can be fixed. If not, a new one is probably $150 or more depending on horsepower.
8/10/2009 8:03:45 PM •
Dynamo...
Answered
on Aug 10, 2009
Jiffy toggle switch
yes, cut the wire about 18" - 24" from the plug end, then install a regular wall light switch in an outdoor style weather proof single toggle switch gang box. Available all day at your local DIY Center.
I have done this with portable pumps that I take with me on the job site at times. I do something a little different by taking one extra step for safety reasons. I use a "Double" gang box instead of a Single and install a GFCI outlet next to the switch where the GFCI is wired first and the switch is wired in after the GFCI so it is protected from any possible shock. and the pump will be protected as well.
Good Luck
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM •
Pool & Spa
Answered
on Mar 17, 2024
Virtual Pool 3. I need serial number for it please.
Free of charge from here. It is 23 years old, license expired.
https://virtual-pool-3.en.uptodown.com/windows
4.5/5 ยท My Abandonware
Description
Virtual Pool 3 is a 3D, first-person sports video game that simulates various cue sports, developed and released for Windows and PlayStation by Celeris. The game features 15 pool disciplines, snooker, and two varieties of carom billiards. Wikipedia
Platforms: Microsoft Windows,
PlayStation Portable,
Playstation
Initial release date: November 14, 2000
Mode:
Multiplayer video game
Genres:
Sports video game,
Simulation Game
Developers:
Celeris,
Digital Mayhem
Publishers:
Interplay Entertainment,
Sony Interactive Entertainment,
2K Play,
XS Games,
Gametapes LLC
Series: Virtual Pool..
1/10/2024 12:18:45 AM •
Pool & Spa
Answered
on Jan 10, 2024
