20 Most Recent Jet JBG - 8A 8" Bench Grinder Questions & Answers
I would recommend calling 1-800-274-6848 for the replacement parts cost and the location of a dealer nearest to you. they might have these available as kit but their breakdown shows individual parts.
Jet JBG - 8A 8"... | Answered on Jan 24, 2010
check out toolbarn.com they most likely will have the parts you need and you can order directly from them
Jet JBG - 8A 8"... | Answered on Nov 18, 2009
One turn.
Grinders | Answered on Nov 17, 2018
Find a Single Pole Single Throw (spst) toggle switch at the local hardware store rated for the load of the grinder. Wire the switch in place and viola you are done! Machines are stupid;they can tell the difference between an oem part and a replacement.
Grinders | Answered on Jul 11, 2018
You can get a replacement toggle switch at any hardware store look in the electrical department.
I cleaned all the wiring connectors etc and used a 4-way extension cord with an i/o switch and thermal/arc breaker surge protector thingy. I had a piece of thick cable with a molded three prong plug which I had removed from a dead paper shredder (I think??) and connected the ground to the case (previously not connected) the black to the black and white to the white. I taped the connections and plugged the test cable into the extension thingy with its switch off and plugged it into the wall outlet. Then, with the grinder switch on, I gingerly switched on the extension thingy and the grinder (sans all moving parts) ie just the motor case and spindle (held securely in the B&D workmate) and viola(!) it worked fine and built up to very fast. I switched off the grinder switch and the motor slowed, taking an age to come to rest.
Then, I fitted a grinding wheel on the left hand thread end, tightened everything and retested, using the grinder switch to start it and it spun really fast.
Soooo, I guess the secure ground is an essential feature of a capacitor induction motor. I checked some old furnace motors that were "maturing" in the basement and they had no capacitor but only 2 wires...
I am now trying to remember which parts came off last and put it all back together. I plan to test it each time I put a part back...just in case. I hate it when you fix something on the bench and when rebuilt, it won't work...don't ask about the electric starter on the snowblower..not a happy puppy!
Please, pretty please and then some, do tell me if my "fix" is wrong and I could risk all kinds of nastiness.
Thanks,
Jenni.
Grinders | Answered on Jun 13, 2018
Jet 577102 is a bench grinder with 1HP motor. It has got guards on the grinding wheel. Dust vents and guard makes the grinder makes it an efficient grinder. 115 Volt is needed to run this high performance grinder.
Grinders | Answered on Jun 09, 2018
Sometimes it could be like this contact by the centrifugal interrupter or the powerswitch or startcapacitor (only if its buzzing) an other kind of relay switch it should be simple to measure it .but to adjust it for time release can be ??.
Grinders | Answered on Mar 12, 2018
To convert it its possible more expensive then buy an other grinder but there is some trick to connect in serial on the powercord a light bulb on a special choosen ability differs on the RPM or use a variable power resistor also in serial connection between on one of the 2 wires on the powercord.
Grinders | Answered on Feb 28, 2018
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Grinders | Answered on Jul 04, 2017
    The dresser wheel is applied strait onto the grinding wheel when you get ridges & valleys on the front of the grinding wheel to make it straight again.
    Grinders | Answered on Mar 15, 2017
    A Drill what has no torque can have bad bearings but i think the drill Brand AND model = X X but it is very often an Li-ion battery tool that is only a 2 or maybe 3 years old but the armatures inside them most of them are coming made by the brand JOHNSON (not Makita) a very nice and very powerfull but also an cheap part and that armatures are far much cheaper then the most people are thinking that the batteries have not enough capacity thats an expensive methode thinking and thats in the most cases wrong sometimes .but 20 on 80 % its the battery sometimes if the tool is too long lasting and working with a bad armature then the batteries will be damaged very soon, if batteries are in short time empty and tool has no power ...
    If you think You have an Li ION Battery tool , like Milwaukee or Panasonic AND very IMPORTANT to know is if the tool is making a terrible piercing sound you can take the test you should see you can only buy a new carbon brushholder if the brushes where worn,.... but if you use the tool daily a 3 or 4 weeks long the brushes are having the same length again and its very bad for the most expensive parts of all .. the li-ion batteries that you maybe have bought and much people (the most ) are thinking that the batteries are having a bad capacity but that is not true ,An anchor and replaceable brush holder is much cheaper and are most (new) only selled in a combination together new Panasonic drawings and the tool sounds again real smooth and 2 or 3 years later then you can maybe again use your batteries for in use in a BRUSHLESS powertool. where only a switch internally should be cleaned with solvent or contact spray and with white grease relubricated .
    Much people think its a problem with the new brushless tools ,but i find out that i have 3 milwaukee brushless tools cleaned the switch and the batteryconnector and have checked the thickness of the contacts, because if the contacts are bad , its not easy to get separate new parts for this brushless models a separate connector for the batteries is not deliverable by the brushless tools by Milwaukee. only in Australie and also and even worser are the contacts on the Dewalt brushless tools have sometimes in a very early time bad contacts even holes on it on the battery + and - connectors on the brushless powertools. strange but often occurs it has also so much power that its like a welding tool between the contacts in the connectors you not can see, and the tools are to little for the jobs where the most people it for used, (the problem is the heat dissipation because of the power and the extent of the modern tools they are often abused , there where better tools can used with a powercord but they have for the torque look alike less power and are for the modern people to heavy to work with.
    Grinders | Answered on Mar 13, 2017
    If this happens just after bought a new tool, Then there is a problem with a start capacitor, or the auxiliary winding from the motor , or just only a loose slide contact if there was a induction motor used, If such a thing happens go back to the dealer for warranty if you in doubt about control if its an easy to fix problem by yourself if nothing was broken.
    A suppression capacitor has 2 wires and can be have red and black wire pair, and a motor have 2 wires from the electric field to the carbonbrushes and 2 other wires from the magnetfield goes to the switch and on the same wires can be connected a parallell suppresion capacitor connected bud in most cases its not needed in practice.
    The other 2 wires have to come from the powercable on the switch the most grinders to find in shops are class 2 angle grinders with double insulation, But If this is an bench grinder there must be a class 1 cable used with 3 wires to earthing a metal point on the housing. look always for the 2 square symbol its class 2 and cable has 2 wires otherwise 3 .
    THE ELECTRONIC assembly must constantly get power .
    2 THINGS CAN HAPPENS 1 The powercable has an broken wire is the most likely problem or if there is an electronic modul with an rpm-magnet disk( need for speedcontrol ) on the end of the armature after the bearing has a problem.it can melting by jam bad bearing and the motor house can be damaged magnetdisk melting with the house
    The electronic modul on itself has a problem in last option.
    Control all the collectors in the commutator if they all balanced together in resist even the 2 stator magnetfieldcoils must be are balanced in resist measure
    Not neccesary to use , but 0.1 uf 300- 400 v to use but some model grinders have a third leadwire to the metal part on the electric field of the motor, special type suppression-capacitor.
    In most cases its not neccesary to use one anymore because of
    repeated complaint like some Bosch models have.
    Grinders | Answered on Mar 06, 2017
    The brand is the most important thing in this question if its an old tool then sometimes only the ball ball bearing can be damaged by the big grinders but in moast cases the little Chinese tools are builded with lightweight metal soft gears that are lubricated with amblygon or renolit grease and sometimes its easy to get spare parts, but depends on the brand and its models budget line or professional.
    Sometimes there are cone wheel crown wheel sets to get for not much money , and sometimes if there is no separate cone on the armature made for replace then its made for only buying an other tool it useless to repair it.
    Jet JBG - 8A 8" Bench Grinder Logo
    2 questions posted
    Top Jet Grinders Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Tom Chichester
    bob walter
    bob walter
    Level 1 Expert
    Are you a Jet Grinder Expert? Answer questions, earn points and help others
    View Most Popular
    Jet Grinders
    • Jet Grinders
    Most Popular Question
    missing tool rests amp shields
    • Grinders
