20 Most Recent
Jandy Lite2 175,000 Btu Propane Gas Electronic Pool Heater Questions & Answers
I have a Jandy Lite2
HI.You'll be needing a propane gas conversion kit.For more detailed information youmay call this #800 374 1500
Flame sensor will not let the boiler run
I just had the same problem. The sensor is a simple device so there's not much that can go wrong with it. My solution was simple. Put some dielectric grease on the wire connection (black wire from sensor to control panel connector). This will stop further corrosion and improve the electrical connectivity. Also, I noticed my sensor wire was sitting too low over the flame probably keeping it from getting hot enough. I pushed the wire up 1/8" - 1/4" to place it higher in the flame. When I fired it up, the sensor worked fine and the burner kept running. Most electrical problems occur at the connections so make sure yours is clean and get some dielectric grease from Radio Shack. This is a 5 minute fix for anyone with fingers, over the age of 18.
* Please use common sense and set the heater to off before you do anything with the door removed. Unless you would like to remove all of the hair on your head in a fraction of a second.
Cheers.
Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
I have a Jandy JXi reading fault fuse link field what do I need to do
The fuse link is a device that will open when over heated. If the exhaust temp is to high it will open and is a one time device. It can not be reset it must be replaced with a high temp fuse link made for the exhaust location. It will have a red mark on it indicating high temp.
Low gas pressure can cause a lean fuel condition that may cause the exhaust temp to rise enough to trip the link. I would also check for scale inside the heat exchanger. Scale inside the heat exchanger will not allow for proper heat transfer to the water, this will cause excess heat to be present in the exhaust. Proper water balance and flow are very important.
Jandy AquaLink RS - no power
If you have checked the circuit breakers and they appear to be functioning properly, here are a few other things you can try:
- Check the GFCI outlet: If the AquaLink RS is plugged into a GFCI (ground fault circuit interrupter) outlet, make sure the outlet hasn't tripped. You can do this by pressing the "reset" button on the outlet.
- Check the transformer: The AquaLink RS requires 24 volts AC power to operate. If the transformer that converts your home's AC power to the 24 volts required by the AquaLink RS is faulty, it can cause the system to fail. Use a multimeter to test the transformer to ensure it's supplying the proper voltage.
- Check the power supply: If the transformer is supplying the proper voltage but the AquaLink RS is still not receiving power, the power supply board may be faulty. Check the power supply board for any obvious signs of damage, such as bulging or leaking capacitors.
- Check the wiring: It's possible that a wire has become loose or disconnected, preventing the AquaLink RS from receiving power. Check all of the wiring connections to make sure they're secure and tight.
If you're still unable to get power to the AquaLink RS, it may be time to call a professional pool technician to diagnose and repair the issue.
How to i fix this problem. 'air sensor shorted' on a Jandy LRZ
- Check the air sensor: The first step is to locate the air sensor and check for any visible issues. Make sure it is properly connected and not damaged.
- Check the wiring: If the air sensor appears to be in good condition, the problem may be with the wiring. Check the wiring for any loose connections or damaged wires. If you find any issues, you may need to repair or replace the wiring.
- Check the control board: The control board is responsible for managing the various functions of the pool heater. If the control board is malfunctioning, it can cause the air sensor to short out. You can check the control board by testing it with a multimeter. If you suspect the control board is the problem, you may need to replace it.
- Check the air intake: If the air intake is blocked or restricted, it can cause the air sensor to short out. Make sure the air intake is clear and unobstructed.
Aqualink RS Heater Button is not turning on
see if hooked up with 4 wire from heater to aqualink if so try checking wires for one loose or off if ok try to use the firemans swith to pins 1 and 2 then heater button will work
Air Flow Fault on Jandy LXI
check the air switch hose make sure not pinched or hole in it then if ok make sure fan running correct speed
