20 Most Recent Makita 12V Cordless Impact Driver - 6980FDWDE Questions & Answers
2answers
Is it possible to replace the batteries in a 12v m...
Unfortunately there are no repairable parts in a battery. Once a battery is dead it's usually best to find a good recycling center for it, most The Home Depot's have one. Makita lists battery 1234 (Part #193157-5) for this tool but it's the old Ni-MH battery. I'd use battery 1222 (Part #192598-2), it's the better Ni-Cd battery.
10/14/2016 9:25:23 PM • Makita 12V... • Answered on Oct 14, 2016
I have a makita 6095d
set it on the drill setting
2/11/2014 5:17:08 PM • Makita 12V... • Answered on Feb 11, 2014
2answers
Disassemble a Makita 6980FDWDE Impact driver
Sometimes fasteners are hidden under labels.
3/19/2013 6:35:04 PM • Makita 12V... • Answered on Mar 19, 2013
Drill just stopped working it was working fine on
Could be the battery(s) went dead, possible but usually two batteries won't go at the same time. If you're sure the batteries are OK, check the 'headlight' when you squeeze the trigger. If it isn't coming on it's the battery or the switch may have burned out. Next, check the brushes. They're under the two caps at the back of the case. The carbon should be about 3/8 to 1/4 inch long and the springs should be in one piece and strong enough to push the brushes down on the armature. Next, put a drive bit in the chuck and check that the armature turns freely. There will be some resistance because the transmission is geared from the motor to the chuck but it should turn smoothly.
8/19/2010 11:42:05 PM • Makita 12V... • Answered on Aug 19, 2010
How do i take apart makita 12volt impact driver
check the L.E.D. and then replace it
4/21/2010 4:43:25 AM • Makita 12V... • Answered on Apr 21, 2010
2answers
Can't separate case to replace broken switch
Have you removed the front housing? It has 4 screws that go into the handle halves and must be removed. As far as internal clips there are none. If you removed the front sometimes the handles stick together and you have to hold each piece and gently pull apart. Hope this helps
4/9/2010 5:27:39 AM • Makita 12V... • Answered on Apr 09, 2010
How to pull apart makita 6980 impact wrench
the battery is removed. remove all screws around the outside of the drill/driver. the side comes off. the motor is a johnson motor connected to the planetary drive and hammer/anvil assembly. the motor drive extends inside the anvil via one gear off the motor. the hammer and anvil come out as one piece. if you depress the center of theanvil with an arbor press, two ball bearings come out and the escapment comes out with the spring. now you can clean the inside of the hammer and gears of the hammer drive.
10/20/2009 8:43:56 AM • Makita 12V... • Answered on Oct 20, 2009
Makita 12v impact driver- no reverse
I would suggest that you go to Makitatools.com and type in your model number and look at the breakdown for complete disassembly procedures. The only problem it could be it the tab on the switch or the shift lever is broken I would have to think it is the switch. Let me know if I can help more.
3/29/2009 4:50:55 PM • Makita 12V... • Answered on Mar 29, 2009
Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
12/31/2008 11:16:04 PM • Makita 12V... • Answered on Dec 31, 2008
I have two Makita chargers and three batteries of various ages. battery chargers no longer charge the batteries.
Do you leave them plugged into the mains all the time? Voltage spike possibly. They can be repaired, but you need the model number in the search query. https://www.google.com/search?q=Makita+charger+repair ..
7/22/2023 12:37:37 AM • Makita Drills • Answered on Jul 22, 2023
2answers
My Makita impact driver led light stays on soon as the battery is clicked in. Any idea whats wrong and how I can fix it?
the light is normally activates by the trigger, so either the switch has gone faulty or the wires running to bulb are contacting. press the helpful button and check link below Makita BTD142 Trigger Switch Replacement
3/7/2023 1:12:49 AM • Makita Drills • Answered on Mar 07, 2023
Makita charger DC18RC i need electrical scheme or D14 diode value .
The Makita DC18RC charger is equipped with a diode labeled D14 that helps regulate the voltage. It is a 1N4007 diode, which is a 1-Amp, 1000-Volt diode. You can find the electrical schematic for the DC18RC charger online with a quick search.
2/16/2023 9:43:01 AM • Makita Drills • Answered on Feb 16, 2023
Electric Makita HP2051 chuck won't close
I don't really know how a chuck works. I use them often on a drill press, cordless drills, etc. My grandfather always said to "check the simple things first." Could something have gotten in the way like saw dust, dirt.....? ? I might suggest trying using compressed air and blow it out? You can buy a can of compressed air at office depot.
8/25/2022 4:27:11 PM • Makita Drills • Answered on Aug 25, 2022
Trouble shooting a makita dc18rc charger dose not turn on
There are no serviceable parts in this charger, it is a replacement item
6/14/2022 4:33:24 PM • Makita Drills • Answered on Jun 14, 2022
Gearbo assembly makita bhp452
You can try the website makitauk.com select parts then choose your tool. Unfortunately it does not break the gearbox down to any detail as it can only be obtained as a complete unit.
6/3/2022 5:18:10 PM • Makita Drills • Answered on Jun 03, 2022
I have an old Makita drill I would like to run with a new Lipo battery?
Lithium Polimer batteries are 3.7volts per cell. They need specialist charging and protection. Maybe not the best choice ...
4/15/2022 7:44:34 AM • Makita Drills • Answered on Apr 15, 2022
Makita 12V Cordless Impact Driver - 6980FDWDE Logo
Popular Tags
11 questions posted
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
View Most Popular
Makita Drills
  • Makita Drills
Most Popular Question
makita 12v impact driver no reverse
  • Drills
