20 Most Recent Homelite 'Yard Broom' Leaf Blower Questions & Answers
wrong hoses connected to the carby
one hose is for suction and has a filter on the end , the other is return
pointing down the hose is out of the fuel
pointing up it is back in the fuel
Homelite 'Yard... | Answered on Jan 24, 2018
Just replace the fuel lines they become hard and shrink allowing leakage. If your tank is like upper the part number is HM-0745499 or like lower part number HM-UP03825 or you can take to local small engine dealer and he will probably change cheaper than you can buy.
Homelite 'Yard... | Answered on Nov 21, 2017
carby diaphragms .
they go hard and do not suck in the fuel
worse if you use e-mix fuel
have the carby overhauled
Homelite 'Yard... | Answered on May 06, 2017
You have a c@carburetor issue.. the needles need adjusting
Homelite 'Yard... | Answered on Nov 05, 2015
look up the unit on the Homelite web site, download the manual, it explains all the steps.
Homelite 'Yard... | Answered on Sep 04, 2015
the fuel lines are crossed at the button, swap them.
Try adjusting the idle screw.
Homelite 'Yard... | Answered on Jul 16, 2015
Dump the fuel and mix up a fresh batch with some fuel system cleaner in it. You may have a partially blocked fuel passage.
If a system cleaning doesnt work check the fuel lines for damage. Many times the fuel line in the gas tank splits and you only get fuel when the level is above the break!
Be safe and good luck!
Homelite 'Yard... | Answered on Nov 28, 2014
if you take apart the carburator youll see a screen under the plate on one side once together turn the mixture screws in all the way till you feel it seat or tighten then back out each screw 1 to 1 and 1/2 turns then start the engine the key is to get it to idle once it idles turn the mixture screw the low side it will say l or h below the screw turn it in which clockwise till it runs smooth then back out slightly till it just starts to miss then rev up the throttle and adjust the high side which is towards the filter turn the mixture screw in till it revs to the highest point which I call the sweet spot your pretty close to what you need
Homelite 'Yard... | Answered on Jul 05, 2014
check for blockage in the air intakes, intake and out put. if you have one with a filter check it to make sure its not clogged. Over heating starts when a vent is clogged or the blower mover needs oiling. do all work with blower unpluged.
Homelite 'Yard... | Answered on Apr 22, 2014
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Homelite 'Yard... | Answered on Apr 07, 2014
I would start off by cleaning the carb. Sounds like it's all gunked up. Is it old? Sounds like it needs a full tuneup. Change the plug, put some fresh gas/oil in there, and clean that carb out with cab fluid.
Homelite 'Yard... | Answered on Apr 03, 2014
Homelite 'Yard Broom' Leaf Blower Logo
258 questions posted
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
leaf blower stay running
  • Garden
