How do I reset
Hi!
Press the Set button to turn on the unit (once programmed, tapping a Personal
Key turns on the unit.) The unit will beep to confirm activation, the Personal Key
numbers (1,2,3,4) will be displayed, and the display will flash.
If you don’t operate the unit for sixty seconds after the unit has been turned on, the unit
will turn off automatically.
If you make a mistake or want to turn the unit off before you have finished
programming it, press the Weight-Only Key to force quit.
Press the Up/Down buttons to select a Personal Key. Once you reach the
Personal Key number you wish to use, press the Set button.
The unit will beep once to confirm.
An arrow icon appears on the left side to indicate age setting.
Use the Up/Down buttons to scroll through numbers.
When you reach your age -press the Set button.
Use the Up/Down buttons to scroll through female or male,
Female/Athlete and Male/Athlete settings, then press the Set button.
Use the Up/Down buttons to specify Height and
The unit will beep twice and the display will flash all data three times to confirm the programming.
The power will shut down automatically.
Good Luck! :)
Cathy
