20 Most Recent
Mabis Neb Xp Portable Handheld Cmpressor Kit Deluxe Questions & Answers
Routine cleaning Mabis XP.
If your unit is the one pictured, he cup with the medication can be taken apart to be cleaned... the top unscrews and the nebulizer comes out....and should be done so after every use. Do not use house hold chemicals to clean the unit. Use a water/distilled vinegar mixture to clean, then rinse with clean water.
I have MABIS healthcare
Hold the scan button and wait for the arrow on the screen. Keep holding the scan button and push the memory button. You have to do it before it beeps.
We have a Mabis signature palm
Lots of things are retained by a metal ferrule when new but often they eventually fail to do the job properly or are lost or corroded away so they must be replaced by one of the huge variety of hose clips available today and/or one of the many sealers or adhesives also generally available.
In addition to those methods there is available the original - three or four turns of parcel wire and a twist to secure or a variation, using a modern nylon cable tie that is long enough to go around twice before tensioning. The parcel wire method can be very neat and further made more acceptable by covering with adhesive pvc tape.
If you have any doubts about your ability to make do and mend, I suggest you find a general auto repair shop that employs a greybeard...
