20 Most Recent
Pride Mobility Products Legend XL 4-Wheel Scooter w/55 AH Batteries & Charger/Flat-Free 13" Tires/22" Seat - Color Candy Apple Red -Brown Fabric Seat Coverings Questions & Answers
On each revelution of the back wheel on a certain
hi im disabled myself,i care thats why im here.please rate me as in thumbs up 1 to 4 for my answer.sounds like your brake shoes could be wore down,but.visit:www.aldatasheet.com download a troubleshooter for your product as a PDF File.save it to your Adobe Reader & if you want as i did print it for future ref.you can keep it in a polythene sleeve folder.hope this was of help,take care colin.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
