20 Most Recent
Royal JS800 Shredder Questions & Answers
How to replace paper sensor
I have never taken one apart that far but you should be able to access the screws to remove the cutters once the top is off. From that point you should be able to see the optic sensor you are looking for. Not sure if this a plug and play type of connection but should be an easy solder if not.
Royal SC800 power shredder I need the large metal gear.
I have the SC800 apart. My problem is not fixing it. I just need the part. The large gear which appears to be made of pewter has a couple of teeth missing. If I could find the part I can fix it. It's a very simple machine. If you know where I can get the part I would appreciate you letting me know..
Sincerely;
Ken Ashley
Paper Jam
try to remove as much as possible from top and bottom of unit with a needle nose pliers or similar tool after that you can saturate any left over paper with shredder oil or a vegetable based LIQUID cooking oil. Let sit for 7-8 hours this should soften the paper enough to power thru the jam.
Where can I get a Manual for a Royal Scriptor ll Typewriter?
You can try searching for a manual for the Royal Scriptor II typewriter on the manufacturer's website or on websites that specialize in providing manuals and instructions for various products. Additionally, you may be able to find a digital copy of the manual on online marketplaces or auction websites, such as eBay or Amazon. If you are unable to find a manual online, you can try contacting Royal's customer support for assistance in obtaining one.
Royal AX160 advances paper at an angle why?
you might need to calibrate a part of the typewriter in order to fix this or there might be broken part of the typewriter.
Please verify how the paper should be advanced based on the typewriter manual. And if it's different in the manual, then you might need to call Royal directly to ask for the closest repair shop you can send the typewriter to so that the issue can be fixed.
Thank you.
