20 Most Recent
Delta Machinery 4x6 Belt/Disc Sander Questions & Answers
What size belt does it use
You did not mention a model number, but the is probably the width of the belt and the 6 is probably the diamter of the disc.
The sanding belt size is probably a 4" wide by 36" long, but it may be 4 x 24" long. Put a string around the rollers, and then stretch the string out straight. Measure it and that is the belt length.
You can find either size belt at sites like
http://www.2Sand.com and
http://www.BuySandpaper.com
Arbor bolt part no. 1347813
you can google your question or better
delta boss spindle sander arbor bolt
About 565,000 result (0.59 seconds)
Balboa hot tub wiring diagram
CAUTION: Electrical work and repairs can be dangerous, especially around water. There is a risk of shock or electrocution, which could result in serious injury or death. We strongly advise that hot tub electrical wiring be referred to a licensed electrician. Local code requirements for wiring vary and may differ from the educational examples on this web site. The local code regulations must be followed, with permits and inspections obtained. The installer should read and follow the hot tub owner's manual and associated electrical component owner's manuals and instructions.
Try this link: file:///C:/Documents%20and%20Settings/Gil/My%20Documents/Troubleshooting%20&%20Service%20Manual%20230V.pdf
