20 Most Recent
Garmin eTrex Venture HC GPS Receiver Questions & Answers
Garmin troubleshooting
replace it or try a master reset. that is an old unit.
https://support.garmin.com/support/searchSupport/case.faces?caseId={dc0a1390-14a9-11de-76c5-000000000000}
My GPS won't stay on
I can solve this by not solving it. First I tried reset the unit to default settings: hold down the power, page, and enter buttons at the same time, a message, "do you really wan to reset..." will appear. Select "yes." If the unit reboots, hurrah. If not, call tech support (1.800.800.1020). Get an RMA, send it back to them for repair. I had purchased mine over 30 days ago but less than 60: Amazon wouldn't replace it, Garmin will either replace or repair. If you want them to send a new unit while the old is in transit, just ask; they will charge and then credit a card once they have the old unit is in hand. Good luck.
How do I calibrate my compass in the eTrex Venture
I will be happy to help you with this. Unfortunnately, the Etrex Venture does not have an Electronic Compass, therefore you cannot calibrate it. What this means is that this unit will show the correct direction of travel as long as you are moving. The unit takes satellite reading every 1 seconds and compares it's location with the last location. This way it can read the direction of travel. It will not give correct readings unless you are moving.
I hope this helps.
My etrex Venture HC will not power up after
I can only suggest that you insure that you have fresh batteries, and that they are installed properly. If you had batteries sitting in it, and they leaked, you might want to examine the contacts and make sure they are clean, and not corroded.
The Etrex are sealed and water-tight. Opening the unit will make them no longer able to resist water as well, and if there is anything wrong internally, it should be sent back for factory repair.
Will not turn on. can
Here's the info that was posted in another form for the "System Software Missing" problem ..
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Good Luck!!
Thanks
Cant find how to manually input cordinates
First create a waypoint, and then modify it. Hold down the enter button for two seconds (the thumb-toggle on the face of the unit). This opens a screen with a number at the top and coordinates of your current location below. Once you've grabbed the coordinates you can change the name and the coordinates and the name and save it as a waypoint. Use the thumb-toggle to bring up number pads and letter pads for each line.
