Cross Aurora AS1512X Cut Shredder
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Cross Aurora AS1512X Cut Shredder?
Troubleshooting and Support
Solved Problems for Cross Aurora AS1512X Cut Shredder RSS Feed Post a New Problem
Runs in reverse only
When I plug in the shredder it starts running in reverse only. The switch does not respond at all. I purchased a new...
1 Solution
HR Specialist
shredder jammed - took apart to get top off, but still unable to get the jammed paper out of roller
1 Solution
Ativa DQ120D
Motor has not been running. When I put a piece of paper in, the overheat/overload lights come on. I believe everything...
1 Solution
Fellows ps60c-2
I have a fellows ps60c-2 shredder and after I removed the seven screws I could not get the powerhead apart. I need to...
1 Solution
Rexel rdx1750 shredder jam
The shredder got jammed with wet paper and the feed slot was full of compacted dry paper when I inherited it. I cleaned...
1 Solution
Shredder won't shred any more.
Shredded 5 or 6 credit cards, one at a time. Will not shred anything now. Can go in reverse, but not forward. Unplugged...
1 Solution
Fellowes Shredder Parent Part # 38605
I have a Fellowes Shredder that needs a new plastic gear. Fellowes tells me that they cannot locate the part due to the...
1 Solution
Unsolved Support Problems
Unsolved Problems for Cross Aurora AS1512X Cut Shredder RSS Feed Post a New Problem
Aurora AS1512X Parts?
One wheel holder is broken on my Aurora AS1512X shredder. It is a molded part of the base. Where can I find a...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Sponsored Links
Loading problems.
Top Shredder Experts
fellowes
5 solutions
Shredders
Ask Me
Guru
dlundmar
2 solutions
Digital Cameras, Computer Components...
Ask Me
Wiz
JayBlair
2 solutions
Office Machines
Ask Me
Wiz
Repair Service
Find Shredder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
