20 Most Recent Sony KDL32L4000 32 in. LCD HDTV Questions & Answers
seems to be fine? replace the main power board
Sony KDL32L4000... | Answered on Aug 01, 2017
screen driver fault probably will need to be changed its on the back of the screen they can go at any time. replace and on the 2 big black chips put some heat sink paste on them help make them last longer and not over heat so quickly. ..
Sony KDL32L4000... | Answered on Sep 20, 2013
No this is what we call a "convergence" problem, it is due to burned out component(s) on the main pcb board. You either will need to get it repaired or replace it, replacing it will most likely be the best option.
Sony KDL32L4000... | Answered on Jan 20, 2012
check the socket
Sony KDL32L4000... | Answered on Aug 20, 2011
The blinking green light is a self-test diagnostic code. Please tell me how many times it blinks in between each pause so that I can tell you what the problem is.
Sai.
Sony KDL32L4000... | Answered on Jun 02, 2011
You may have failing T-CON board, or worst case will be the LCD pnael itself. You need to have it looked at which will not be cheap!
Learn more here:
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
Most of the SONY TV's use SAMSUNG LCD panel and they have a lot of problem with it after two years, you can Google " SONY LCD TV LCD SCREEN PROBLEM" and you will see alot of upset people who own SONY after two years.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Sony KDL32L4000... | Answered on Apr 27, 2011
Ur tv have a bad tv Tuner signal board.That the board,where the tv imcomming broadcasting signal cable plug into it.U can take things aparts and putting back again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole tv Tuner signal board for a replacement.
Sony KDL32L4000... | Answered on Mar 21, 2011
Hi.
Use different input cables and check using at list two different input devices (eg. a DVD and a receiver box or a playstation, and the internal tuner).
If the problem depends on the device connected or on the cable, then it is either cable, external device, or the terminal connection circuit in the TV, which in this model is integrated with the TV.
Before testing try doing a power reset by disconnecting TV power cord for five minutes.
If the lower part of the display has a red tint or if it is darker, and problem is none of the above, then the TV is defective.
If the lower part of the screen is reddish, and light is normal, then it is probably the main board. Try going to display settings and change from progressive scan to interlaced (eg from 1080p to 1080i, or to 740i). That may bypass the problem in case the fault is related to progressive scan logic circuits in PC board.
If the lower part of display is darker, then it is a back-light problem. In that case parts to be tested are inverter, psu, pc board and display.
Regards.
Ginko.
Sony KDL32L4000... | Answered on Feb 24, 2011
Call Sony right away. They have been having lots of issues with this model. If you are nice (and pleasantly) persistant you may be able to get a replacement at a reduced price. Definately talk to them about repair as well however many report their out-of-warranty (same model as yours) tv was not worth repairing. Many issues on the web for this model. In several of their models over the past 6-7 years there have been many class-action lawsuits. My in-laws got a brand new Sony 52" TV at 1/2 price because of all of the lawsuits over models before yours. They are likely in the mood to work with you right now.
Sony KDL32L4000... | Answered on Dec 04, 2010
Hi
there 4 possible reasons
1.check power suply
2. check antenna cable
3. check if you have it on Tv mode
4.check if your power trandormer is ok
Sony KDL32L4000... | Answered on Nov 25, 2010
Sony KDL32L4000 32 in. LCD HDTV Logo
41 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
sony kdl32l4000 all sudden dark
  • Televison & Video
