20 Most Recent Sony Bravia KDL-46Z4100 46 in. LCD HDTV Questions & Answers
for Bravia's.. To turn off the demo mode, press and hold the MENU button on the TV for more than 10 seconds. The message Demo mode: Off will appear on the screen.
Let me know if this helps.
Sony Bravia... | Answered on Feb 21, 2018
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony Bravia... | Answered on Aug 29, 2017
The problem is called pixel re-stain, it usually happens on some old LCD panels, in your case, the TV is not worth to fix.
Sony Bravia... | Answered on Apr 26, 2017
The TCON Board or the LCD panel is faulty. Can confirm By replacing the TCON board.
http://electro-medical.blogspot.com/
Sony Bravia... | Answered on Jun 09, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Sony Bravia... | Answered on Feb 21, 2016
It's worth it for a project to learn and save some money, but flat screens are becoming cheaper and cheaper everyday.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Sony Bravia... | Answered on Feb 06, 2016
check cable, if its using an HDMI, replace it: if component RGB cable, reseat or replace.
Sony Bravia... | Answered on Oct 03, 2015
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sony Bravia... | Answered on Sep 08, 2015
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Sony Bravia... | Answered on Aug 10, 2015
Hi Aarom,
According to Sony literature 14 blinks indicate a panel problem. Please have your TV checked by some good TV Tech.
Sony Bravia... | Answered on May 10, 2015
Tries tv unplug,replug it back about an hour later for the tv for a resetting back to the factory setting.Go into the tv menu go to Audio Setting go down to do a resetting back to factory setting.These steps will help the tv to get the tv audio back.
Sony Bravia... | Answered on Jan 20, 2015
See if this helps you. There are connection diagrams
https://docs.sony.com/release/KDL40Z4100_qs.pdf
Sony Bravia... | Answered on Feb 22, 2014
Sony Bravia KDL-46Z4100 46 in. LCD HDTV Logo
75 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony bravia picture turns green
  • Televison & Video
