20 Most Recent Sony Bravia KDL-40W4100 40 in. LCD HDTV Questions & Answers
New screen required as it has been damaged. Probably cheaper to replace the set.
Sony Bravia... | Answered on Jun 20, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here...
Sony Bravia... | Answered on May 06, 2016
The problem is most likely a failing electrolytic capacitor in the convergence section of the circuitry. It may not be economically repairable. You can (after unplugging the set) take a good look at all the electrolytic capacitors hunting for signs --crud on the ends, bulging, burning, etc.
Sony Bravia... | Answered on Jul 28, 2014
Firmware corrupted. Contact the authorized service center.
Gopakumar Gopalan Google
Sony Bravia... | Answered on Mar 04, 2014
My KDL-52W4100 just started doing the same thing. It blurs down the right side of the screen, then goes back to normal after it warms up. Does anyone know whats up with this?
Sony Bravia... | Answered on Jan 20, 2014
Before you do the auto search for the programmes please try to do the factory re set from set up menu. hope your problem will be solved.
Sony Bravia... | Answered on Nov 24, 2013
At first, check if battery contacts inside the battery compartment for any dust of rust accumulated. Clean them well, and insert fresh batteries and check. Check its infrared emission. You can check it by using a cellphone with camera option. If there is no infrared emission, you have to check its infrared LED at the front of the remote control for damage or loose solder terminals. For this, you have to open the remote control. If you wish to get more details about how to check and clean a remote control, visit this site. It has a post, that describes how to clean a remote control. Good luck.
Sony Bravia... | Answered on Feb 07, 2013
Check this link.
Sony Bravia... | Answered on Nov 26, 2012
you should press 10000, which is the code
Sony Bravia... | Answered on Nov 22, 2012
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Sony Bravia... | Answered on Nov 14, 2012
Look first to see if same issue on all inputs to set---does it do this with a DVD etc hooked to a rear input or not?
Sony Bravia... | Answered on Jun 11, 2012
what is being used for signal and how are you connected for that?
sounds like a bad main or digital board--you under warranty with this unit?
Sony Bravia... | Answered on Apr 02, 2012
Sony Bravia KDL-40W4100 40 in. LCD HDTV Logo
46 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
own sony bravia kdl 40w4100 tonight ran
  • Televison & Video
