20 Most Recent Canon EOS 400D Digital Camera Questions & Answers
This error message is common to a broken lens ribbon problem. Does the lens work in manual and not in auto. If so it could well be the problem. The fix is to have the lens ribbon replaced.
Canon EOS 400D... | Answered on Feb 06, 2016
Dear!
It would be easy or very bad. First you can check your memory card pins bent in receptance unit. It is hard to see. You should use flash light with magnifying glass. It not the problem then mostly like some loosen screw running around and shorting the circuitry. One of these is very common problem of a certain canon product. It is an engineer defect design. It should be factory recall problem but no they don't recall the problem. Both problem solving need some delicate skill. They need both disassemble! Hope you luck! A Professional Camera Clinic Guy!
Canon EOS 400D... | Answered on Mar 31, 2015
What wide angle lens is it need f number it may be to old to work on eos 400d
Canon EOS 400D... | Answered on Aug 21, 2014
If it is just one Flash card, then the card may have failed. If however you have tried other Flash cards and you get the same problem then one of the contacts (small gold coloured pins inside the camera that mate with the Flash Card) may have bent causing the error.
Canon EOS 400D... | Answered on Apr 22, 2014
Take it off green rectangle and set it on P. Then the flash will only pop up if you push the flash button
Canon EOS 400D... | Answered on Nov 18, 2013
Poor how? What are you shooting?
Canon EOS 400D... | Answered on Aug 21, 2013
Check your battery level, if not, there might be a loose cable inside your camera, or a faulty button. Might need to open it.
Canon EOS 400D... | Answered on Jun 25, 2013
just replace card and try or format card your card have some poblem
Canon EOS 400D... | Answered on May 20, 2012
Unplug the camera if it's connected, then shut down and restart your computer.
In the future you might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Canon EOS 400D... | Answered on May 07, 2012
Hi
This error could indicate a lot of problems with the camera.This ranges from bad battery ,bad memory card or even bad lens contacts wit the camera body or simply putting it,general operation failure.
Try removing the battery and re-loading it again.
Solved?
Then you may need to update your camera's firmware to the latest version which seems to solve this problem.
Updates for your camera are on the link below.
web.canon.jp/imaging/eosdigital3/e4kr3_firmware-e.html
Hope it helps.Thanks!
Canon EOS 400D... | Answered on Feb 28, 2012
Just go to Canon's website where you'll find a section called Customer Support or similar wording.
There you'll find easy steps to getting the manual for your camera downloaded.
Canon EOS 400D... | Answered on Sep 26, 2011
Sigma makes lenses with a variety of mounts to fit a variety of cameras. A lens with a Pentax mount, for example, will not fit a Canon camera. Assuming you get a lens with a Canon mount then yes, it will work on your Canon.
Canon EOS 400D... | Answered on Aug 16, 2011
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Have a Good day!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Canon EOS 400D... | Answered on Jun 06, 2011
The EOS 400d is called the Rebel XTi in some parts of the world. You can download the XTi manual and more from
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/digital_rebel_xti#BrochuresAndManuals
Canon EOS 400D... | Answered on Dec 10, 2010
The 400D is called the XTi in some parts of the world. You can download the XTi manual from
Canon EOS 400D... | Answered on Nov 26, 2010
Canon EOS 400D Digital Camera Logo
55 questions posted
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
error 99 says card faulty
  • Cameras
