20 Most Recent
Nintendo Controller add-on Nunchuck for Wii Questions & Answers
Got a NYKO wireless nunchuck and it is not syncing
if you push the sync button on the connecter to the wiimote for 2-3 seconds it'll light and stay lit, then push the sync button on the nunchuck and it'll light and stay lit and you are now connected!
1/12/2014 4:30:48 PM •
Nintendo...
Answered
on Jan 12, 2014
What does blue flashing on the nunchuck
this is what happens when the device attempts too connect to the console. the solution is very simple as well. simply remove the battery cover on the the wii-mote. now open the memory card door of the front of your wii. note the red button on both the wii and the wii mote. now simply press and hold both and then the wii mote should automatically pair to the console. repeat whenever needed. Hope i was a help to you today.
4/4/2013 5:50:24 AM •
Nintendo...
Answered
on Apr 04, 2013
Nunchuck wii problem
Most likely not a fault with either. Try not touching the nunchuk while the game is powering up, as moving the joystick while the game is powering up can cause these issues. If the problem is still happening, click the Wii Home button and open the Wii Remote Settings at the bottom of the screen. Choose the option to reconnect the remote, and then try again. If this doesn't work, ai am not really sure what is the issue. You may need to send to NOA for a checkup.
11/15/2012 12:38:24 AM •
Nintendo...
Answered
on Nov 15, 2012
My nunchuck keeps moving to the left
Have you tried removing the batteries and then moving the stick in a clock-wise then counter-clockwise direction. Also try clicking the joystick in to see if that help. Is there a reset button in the battery compartment?
6/1/2012 12:35:54 AM •
Nintendo...
Answered
on Jun 01, 2012
I have four nunchucks, and
hay this is an easy fix.. u need to reset ur controllers.. to do this....make sure when u plug the nunchuck into the remote it's in it's normal state .... then....
Push buttons A, B, plus(+) and minus(-) on the remote at the same time. Hold for three seconds that should be enuff time for it to reset it self.... (-_-)
10/29/2011 2:06:04 PM •
Nintendo...
Answered
on Oct 29, 2011
My nunchucks and sensor bar is not working what do
If the sensor bar is not functioning, then the nunchuck will not work as well.
My suggestion is to check the connection for the Sensor Bar in the back of your Wii. Check for frayed cable, bends, or bare spots in the wire.
If you locate anything wrong, the sensor bar will need to be replaced.
3/11/2011 2:20:31 AM •
Nintendo...
Answered
on Mar 11, 2011
