20 Most Recent Haier HD306 Dehumidifier Questions & Answers
How humid are the conditions? if dry, will not extract water, can only extract water from humid conditions
Haier HD306... | Answered on Aug 13, 2014
http://www.retrevo.com/support/Haier-HD306-manual/id/951dj394/t/2/
Haier HD306... | Answered on Sep 23, 2011
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Haier HD306... | Answered on Jul 26, 2011
hELLO,
Try to replace or clean the filter
Haier HD306... | Answered on May 27, 2011
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Haier HD306... | Answered on Jun 03, 2010
IF IT IS IN A WARM ENOUGH AREA YOU COULD BE LOW ON FREON
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Haier HD306... | Answered on Jan 13, 2010
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less
Is the fan blowing out air? If not
It made no sense to me that despite no visual issues, the fan motor is bad. So, with further research it turns out that the true culprit is the small thermistor/thermal fuse between the orange wire (ground) and motor winding wire. The thermistor is taped underneath the silver aluminium and yellow tape on the fan motor. I heard about this bad (open/no continuity) thermistor makes almost >99% of the fan motor problem regardless of any brand name because this cheap c-fram fan motor is NOT made in USA. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a thermistor or type of temperature sensor connected between the orange wire and a motor winding wire. On my motor this was no longer working.
The part marked "JET 123 NM1 2A 130C" is a thermal fuse. The 130C is the temperature rating. When the motor get hot (130C / 265F) the fuse opens. The circuit is broken and the motor stops.
The motor is still good. The fuse is blown. It must be replaced to get the motor running again. You could bypass the fuse but then you invite a fire hazard.
A replacement fuse is available from Digi-Key. It is a Cantherm SDJ1 DF128S (128C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1133-ND
Part cost 98 cents
You might want to go with the next higher temp (141C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1134-ND
Haier HD306... | Answered on Jan 06, 2010
Our HD306 model was used for one season and will not pull out water when we recently plugged it in.
Haier HD306... | Answered on Jun 17, 2009
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Haier HD306... | Answered on May 18, 2009
Fixya does not sell Haier replacement wires and connectors.
Haier... | Answered on Jul 15, 2018
Haier HD306 Dehumidifier Logo
17 questions posted
Top Haier Dehumidifiers Experts
Shawn DuRee
Michael Youngman
Michael Youngman
bigdaddyd2
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
Haier Dehumidifiers
  • Haier Dehumidifiers
Most Popular Question
not operating properly doesnt draw water
  • Dehumidifiers
