20 Most Recent HP Disk drive - CD-RW / DVD-ROM combo - internal Burner Questions & Answers
2answers
How to burn an ISO FILE to a cd disk and make it bootable
an iso file is an image of a cd or dvd ...so when you burn it you need to burn it as a disc image.....nero burning rom gives this a one of the options when you go to burn....as far as making it bootable oyu'll need to play around with the ISO (unless of course the image is of a bootable disc)
11/17/2015 7:34:33 AM • HP Disk drive -... • Answered on Nov 17, 2015
2answers
It doesn't recognize/read/play cds or dvds that
Hello there:
first off i would go to device manager and open it and look for the area that says disk drives and open it and look for your cd/dvd right click on it and select remove than confirm removal of the device now at the top of the page you will see view and click on it and where it says scan for hardware change select that and then windows will install the device again you will see new hardware found on the taskbar and it will tell you when the device has been installed and is ready to be used. ok?
i hope that this information is very helpfull for you
please rate this information i have provided for you ok?
best regards mike
(USN RETIRED)
9/5/2014 7:21:44 PM • HP Disk drive -... • Answered on Sep 05, 2014
Dont read cds can read before
In most cases the cd-rw's after a time there stop reading cd's or dvd's . u can't do anything about that issue because it's from laser that had benn moved a mm grade of accuracy . have a nice day
1/2/2011 3:05:56 PM • HP Disk drive -... • Answered on Jan 02, 2011
2answers
How so I manually remove a disk from an HP
Can you find a very small hole, about the diameter of a paperclip wire, on the front of the unit, maybe behind the lid? If you take a paperclip and straighten it out, gently push it into that hole until you see the disk tray push out slightly, then CAREFULLY pull the tray out the rest of the way with your hand. It should be done with the power off so the disk drive doesn't try to close itself on your fingers! Hope this helps. I've included a video I found on youtube.com that shows exactly how to do this, it only takes a second!
12/19/2010 4:56:42 PM • HP Disk drive -... • Answered on Dec 19, 2010
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered Yesterday
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
2answers
What to try now hp omen dv7 battery issue
If calibrating the battery didn't work for you you could try a hard reset of the battery:
3/6/2024 9:11:06 PM • HP Computers &... • Answered on Mar 06, 2024
2answers
I have installed 4G RAM, Is that the MAX supported or may upgrade to more ?
Memory Max Maximum supported = 8GB
2/17/2024 5:55:53 AM • HP Computers &... • Answered on Feb 17, 2024
3answers
I have an HP Pavillion533w that will not turn on when I press the power button.
Here are troubleshooting steps for when your computer won't start:
2/15/2024 7:54:52 PM • HP Computers &... • Answered on Feb 15, 2024
2answers
Why won't my HP tower computer turn on?
Here are some troubleshooting steps for when your computer won't turn on:
2/15/2024 7:54:39 PM • HP Computers &... • Answered on Feb 15, 2024
2answers
Hp probook 4440s keyboard light function key shotcut
To adjust the keyboard backlight on your HP ProBook 4440s, you typically use the "Fn" (function) key in combination with one of the function keys that has a symbol representing the keyboard backlight.
2/12/2024 8:56:21 PM • HP Computers &... • Answered on Feb 12, 2024
Look for the driver for my Pc media center M7000 product M7682fr system number RF893AA ?
Visit the HP Support Website: Go to the official HP support website at HP Customer Support. Enter Your Product Details: Enter the product name "Media Center M7000" and locate the specific model or product number. In your case, you've provided the system number RF893AA, which is also known as the product number. Locate Drivers and Downloads: Once you've identified your product, navigate to the "Software, Drivers, and Firmware" section. Choose Your Operating System: Select your operating system (e.g., Windows) and its version (e.g., Windows 7, 8, 10). Find and Download Drivers: Look for the drivers related to your PC's components, such as graphics, audio, network, etc. Download the required drivers to your computer. Install the Drivers: After downloading the drivers, run the installation files and follow the on-screen instructions to install them. Restart Your PC: After the installation is complete, restart your PC to apply the changes. If you face difficulties finding the specific drivers for your model or if your PC is quite old and HP no longer provides drivers for the chosen operating system, you may need to consider using default drivers that come with the operating system or upgrading your operating system.
2/12/2024 8:56:17 PM • HP Computers &... • Answered on Feb 12, 2024
HP Disk drive - CD-RW / DVD-ROM combo - internal Burner Logo
5 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
burn iso file cd disk make bootable
  • Computers & Internet
