20 Most Recent
Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability Questions & Answers
Keyboard wont play with ac adaptor
Hi, Assuming you have tested with another adaptor then invariably it is a broken solder joint on the power input connector.
Re soldering will work but eventually the same thing occurs.
Set the connector in epoxy resin (Araldite) or better still mount a new connector in the case and wire with flying leads.
All the best, Chris the Fader.
Manual Casio CTK-650
Hi! When I turn on my keyboard it shows "03.2" on the multifunction display and the lights of "Split", "Digital effect" and "Touch response" remain "ON" and in someway it get blocked for the most of the functions. I cannot turn off that lights. Please, help me!!! You can answer me to
[email protected] Thank you very much
CANNOT FIND SOFTWARE FOR CASIO LK125 PIANO
CASIO LK125 does not have any MIDI interface so I do not understand what software you are after.
manual available at:-
http://support.casio.com/manualfile.php?rgn=4&cid=008006139
Keyboard not powering up. Want to change the
There probably is NOT a fuse and usual cause is problem with the adapter or the power connectors. Broken solder of the connector in the keyboard is common. Broken cords on the adapter is common as well.
Casioik90tv wont work trough power
Likely a problem with the power connector or the power adapter. Make sure you are using the original power adapter as often replacements don't work and universal adapters seldom work.
