20 Most Recent Dynex DXR24TV 24" TV Questions & Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Dynex DXR24TV... | Answered on Apr 12, 2017
There are so many reasons for loss of color to picture. The troubleshoot should start with antenna connection itself. The color system settings should be checked. Tuning accruracy [tuner fault] should be checked. Setting of color level should be checked. Even if it seems to be simple fault, the actual might be hard to rectify by the user. any fault with chroma section cause this fault. In fact, your set need a through check up. Contact any experienced service tech:.
Dynex DXR24TV... | Answered on Jun 23, 2012
Go into menu with remote control & change picture size. Depending on which station you are watching you may have to change it to suit your viewing preference. They transmit in different sizes
Dynex DXR24TV... | Answered on Apr 04, 2012
When you find out, could you please send it to me. I can't operate a new 32" flat screen with my cable remote.
Dynex DXR24TV... | Answered on Jan 30, 2011
you dont need the code for real all you have to do is follow the steps necessary to enter a code but instead of entering code press the channel up button repeatedly until it changes the channel when it does press enter/ok or similar button and you have a nice working remote for your tv without the code!!!! Hope this works out for you, it has for me everytime i get a universal remote its just a lot faster to just keep pressing the channel up button instead of unfolding the paper finding codes and what knot. GOOD LUCK!!!!
Hi..
About the service mode, service manual for Dynex CRT models is not easy to find.
Test the following, it works on some Dynex and Insigna TVs:
Take apart the remote and find the hidden buttons inside the remote.You should find several switches not connected to keyboard. Locating the right ones is a problem that you must solve on the spot.
Turn the TV on and push down first the left hidden button and then the right hidden button without holding. If that worked the word TEST will be displayed in upper right corner of the TV screen. Use number keys to select menus, nr.1 and nr.3 have video adjustments needind in convergence.
That is the way it used to work on Dynex/Insignia CRTs.
by the way if the "Raster has About 1/2" black at bottom till tv warms up 5-10 minutes" that means that the problem cannot be fixed with service mode adjustment. Problem is a defective component. Check STK ICs soldering joints, read Ohms on resistors and ensure they have continuity
If any of this help, do not forget to accept the solution.
Regards.
Ginko
Dynex DXR24TV... | Answered on Sep 28, 2010
have you try to clean the inside contact and sheet ruber,whit wood alcool and rebuild it/ try this fist,
i hope that will help you
Dynex DXR24TV... | Answered on Apr 23, 2010
try to find a multi-video selector swicth that the best you can do
Dynex DXR24TV... | Answered on Feb 13, 2010
Try going here for the code.You may need to get a digital antenna for a clear picture.About 20 bucks.
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/Dynex%20TV%20Universal%20Remote%20Codes%207-9-07.pdf
Dynex DXR24TV... | Answered on Sep 20, 2009
Dynex DXR24TV 24" TV Logo
22 questions posted
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Televison & Video
Most Popular Question
new dynex 24 in tv working good but only
  • Televison & Video
