20 Most Recent DXG Technology DXG-506V Flash Media Camcorder Questions & Answers
SOFTWARE
JOEL, YES THERE IS USUALLY SOFTWARE THAT COMES WITH THE CAMERA OR IF NOT YOU SHOULD BE ABLE TO GET IT FROM THEIR WEBSITE. BUT YES, IT USUALLY TAKES A SOFTWARE PROGRAM TO DOWNLOAD, UNLESS YOU USE WINDOWS PHOTO GALLERY OR PICASA WHICH HAVE SOFTWARE IN THE PROGRAM TO RECOGNIZE A LOT OF CAMERAS. YOU MIGHT TRY ONE OF THOSE TO SEE IF THEY WORK WITH YOUR CAMERA. I TAKE IT YOU HAVE THE CABLE TO CONNECT YOUR CAMERA TO THE COMPUTER? IF NOT TRY A PLACE LIKE WAL-MART, CIRCUIT CITY OR LIKES TO GET A CABLE. HOPE THIS HELPS. EMAIL IF YOU NEED MORE HELP.
ARCLIGHT1217
11/4/2008 7:33:30 AM • DXG Technology... • Answered on Nov 04, 2008
Dxgmodel 301vdvc/mpeg4
You may download a copy of the manual here.
7/6/2012 5:04:37 PM • DXG Technology... • Answered on Jul 06, 2012
Took our DXG camcorder to
If you can clean the corrosion off down to the metal, you will be ok. Spray some electrical contact cleaner on them to flush off all the chemicals, and wipe them dry with a soft cloth. You may have to use some fine grit emery cloth to get all the corrosion and oxidation off the terminals. Then reclean them good. Corroded and oxidized battery terminals are the number one problem with digital cameras, since they use such a low voltage, and it's extremely critical to keep the contacts clean and perfectly conductive.
Cleaning the contacts should get you going again. Good luck, and thanks for using FixYa.
9/4/2010 5:12:04 AM • DXG Technology... • Answered on Sep 04, 2010
After installing newly charged batter when I turn
How old is the batt.? I purchased a digital camera and after 2 months the batt. went bad. Have had it now 2 years and several batt.later.
12/25/2009 10:01:51 PM • DXG Technology... • Answered on Dec 25, 2009
How do you get an LG LV720 video cassette recorder out of safe mode?
To get your LG LV720 video cassette recorder out of safe mode, you can follow these steps: Locate the original remote control that came with your VCR. Look for a button marked as C.LOCK or LOCK. Press this button. This should allow you to exit the safe mode3. If you don't have the original remote, you might face some difficulties. Some users have reported success by pressing the record button for 6 seconds on their Panasonic VCRs but it's unclear if this will work for an LG model.
4/21/2024 3:09:22 PM • Video Cameras • Answered 3 days ago
Movavi video editor 11
Hi, which type of system you use ? if your computer is not equipped with the requirement, this will not work properly,
3/17/2024 9:39:09 PM • Video Cameras • Answered on Mar 17, 2024
How to factory reset model sdr-b853009?
All question need 'make model (what it is) as first 3 words please. https://www.google.com/search?q=sdr-b853009+reset All answers can be found on Google. ..
3/12/2024 4:40:20 AM • Video Cameras • Answered on Mar 12, 2024
My foxelli trail camera is only doing black pictures at night?
I would check the IR lamps work on the front of the camera.
3/11/2024 7:23:24 PM • Video Cameras • Answered on Mar 11, 2024
What is error code EO1
Depends on what type of camera but this site may help you. https://www.instructables.com/Fix-JVC-GR-DV800U-Camcorder-Error-Messages-E01-E02/
3/11/2024 3:50:38 PM • Video Cameras • Answered on Mar 11, 2024
2answers
I am looking for an Instruction manual for Zennox 4000 camcorder please
https://files.canon-europe.com/files/soft29721/Manual/MV550i_530i_En.pdf
2/21/2024 2:12:51 AM • Video Cameras • Answered on Feb 21, 2024
Wilderness Innovations trail cam model number K8B37D. Owner's Manual please?
That particular model doesn't seem to be listed anywhere. Contact the maker direct. https://www.google.com/search?q=Wilderness+Innovations+trail+cam+K8B37D+manual ..
2/5/2024 8:50:23 PM • Video Cameras • Answered on Feb 05, 2024
Rca vhs camcorder cpr300 won't playback or record
This may be bad belts, and what you should check for is the belts on the side of the tape deck toward the lens and pickup(front), and the drive belt in the middle. All the belts are under the circuit board, so you need to remove that to get at them, and then you can replace them with rubber bands of same or slightly smaller size. Use a screwdriver to help get the old belts off, and put new ones on. (In the tight space) Then check if the tape deck opens and closes, and see if the tape moves when you hit play/record. If you put in a tape you know has a video written onto it, then put that in, and try to play it. If you get a noisy or staticky picture, then try wiping the video head drum(Big shiny cylinder that spins, with the small slits in the side.) with some alchohol and a glasses cleaning cloth or paper. Also, wipe the audio/control head, the silver box that the tape runs across just before it goes by the black roller. Also, check for gunk or obstructions that have gotten in the mechanism of the tape deck in the back. Make sure the video drum is spinning, and that the tape is pulled out of the cassette by some small rollers and wrapped around the video drum DURING playback/record. I say 'during' because some camcorders will retract the tape back to the cassette for fast forward and fast rewind. I hope you get your camcorder to work! Thanks! 73 Sincerely, Beauregard42. (<-- My YT channel where I have some tech stuff)
1/9/2024 12:49:45 AM • Video Cameras • Answered on Jan 09, 2024
2answers
Error occurred please turn unit off then turn on again
Then what happened ?
1/2/2024 9:13:47 AM • Video Cameras • Answered on Jan 02, 2024
2answers
Silicon Valley Products SVP HDDV 2600 video camera. How to download drivers for it please?
There is no software online, it was a 'one hit wonder' and it says the disc that came with it only contained drivers and Ulead Video Studio 7, Ulead Photo Express 5. Fairly typical on such devices. Everything for $100 including the disc. https://www.ebay.ca/itm/275425639098 https://www.manualslib.com/manual/315830/Svp-Hddv-2100.html Driver Guide says it has them. Or you can connect the the camera to the computer, turn it on, then go to Device Manage in Settings and you will see a device with a banged out triangle icon,. Right click and click Find Driver. Microsoft should have one that works. https://www.google.com/search?q=svp+hddv+2600+video+camera+drivers+download ..
12/30/2023 3:11:37 AM • Video Cameras • Answered on Dec 30, 2023
DXG Technology DXG-506V Flash Media Camcorder Logo
1 questions posted
Top DXG Technology Video Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
View Most Popular
  • DXG Technology Video Cameras
Most Popular Question
software
  • Video Cameras
