BenQ FP222Wa - Flat panel display - TFT - 22" - widescreen - 1680 x 1050 - 300 cd/m2 - 700:1 - 5 ms ...  LCD Monitor
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with BenQ FP222Wa - Flat panel display - TFT - 22" - widescreen - 1680 x 1050 - 300...?
Troubleshooting and Support
Solved Problems for BenQ FP222Wa - Flat panel display - TFT - 22" - widescreen - 1680 x 1050 - 300 cd/m2 - 700:1 - 5 ms ...  LCD Monitor RSS Feed Post a New Problem
Acer Aspire 1710 laptop monitor is down
Hi, monitor on my laptop went black in a moment. Looks like computer is continuing to work. When making a closer look at...
1 Solution
L222WT flatron 21.6 monitor is not working
When the monitor is turned on, the LG symbol/logo appears as if it will then go to the Windows Vista page. Instead,...
1 Solution
bzzzing noise coming from monitor
my monitor is making noises, like an electrical bzzz. Could it be a corrupt profile or is it hardware? other than that,...
1 Solution
dell monitor for dimension 2350
lately my monitor keeps blanking out... I was told that a patch could fix the problem.. I hooked another monitor to the...
1 Solution
.ct 2070 display not clear
Hi,  we have the lct 2070 akai monitor.  I have hooked it to the computer and its working but, the fonts are...
1 Solution
Dual monitors in XP Pro - HP Pavilion...
My HP Laptop has the NVIDIA GeForce FX Go5200 adapter. I went in to the "display" options in the control...
1 Solution
1inch black line down right hand of screen
I cannot get a full screen on my acer x223w monitor due to a 1inch black line down right hand of screen. this only...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Viewable Picture Size22 in
Contrast Ratio 1,000:1
Brightness 300 cd/mē
Monitor Type Flat Panel LCD TFT (Active Matrix)
Dot Pitch 0.282 mm
Aspect Ratio 15:9
Response Time 5 ms
Color Depth 24-bit (16.7M colors)
Connectivity
Digital Video Input StandardDVI-D
Technical Features
Form FactorDesktop
Regulatory ApprovalBSMI · CE · TUV GS · FCC Class B · C-Tick · CSA · VCCI · ISO 13406-2 (Pixel defect guidelines) · TCO-03 · TUV-ERGO · CCC · FIMKO
Synchronization Range - Horizontal30 - 82 kHz
Max. Viewing Angle - Horizontal170
Max. Viewing Angle - Vertical160
Native (Recommended) Resolution1680 x 1050
Synchronization Range - Vertical56 - 76 Hz
Supported Models
Black, Silver
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
Loading problems.
Top Monitor Experts
CosmaP
1 solutions
Modems, Software, Computer Hardware, Storage and Media,...
Ask Me
Guru
lickwish
2 solutions
Cars, Cellular Phones, MP3 and Digital Media Players...
Ask Me
Guru
freetek
7 solutions
Ask Me
Wiz
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
